I received my boost gauge today but I'm having a lot of trouble installing it.
I've taken the hose that connects from the throttle body to the boost sensor, out of the boost sensor and put my T piece there. I have a short hose connecting the T-piece back to the sensor and the last hose attached to the T-piece is the one that runs to the gauge. The hose supplied to me had a larger diameter than the hole drilled into the back of the gauge, so i carefully used a screwdriver and incresed its diameter so that the hose fits tightly inside.
Now... if I have done anything wrong so far, let me know.
For the electricals... I got really confused. I don't have a screwdriver long enough to reach up into the steering wheel column and get the 4 screws that require a pretty thin and long neck lol. SO what i decided to TRY to do was connect it through the fuse box under the bonnet. I tried putting the red wire (manual says it's supposed to go to ignition (12V)) to the 30A "ignition" fuse and grounded the gauge on a bolt on the chasis inside the car.
When i turn on the car, i hear a lot of air going into the gauge through the house, but when i increase the throttle, the gauge doesn't work :(
Please help!!
P.S there are 2 other wires on the gauge harness (yellow one = standard ignition, white one = ignition light?)
I don't have a multimeter so I can't test what wire is active when the car is on, or when the lights are turned on.. but i can always tap into the cigarette lighter light i guess.
https://www.sau.com.au/forums/topic/415623-help-installing-my-boost-gauge/
There shouldn't just be a "hole" in the back of the gauge, there should be a nipple to put the hose onto and you shouldn't hear any air.
That's a leak. Do you have a pic of the back of the gauge?
Power for the gauge is easier to get from the cig lighter itself and light it off the cig light.
LOL. You are gonna have to connect the sensor too!
You have bought an electronic Boost gauge. The sensor has the hose go to it and it sends the signal to the gauge.
(just like the stock gauge).
A mechanical Boost gauge has the hose go straight into it. no sensor.
But the gauge i bought is mechanical, it isn't electronic :\
this is the ebay link to it
http://www.ebay.com.au/itm/400336875504?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_5644wt_1139
lol, oh man i'm so confused now...
HMM ok, but the sensor only has one nipple on it. How am i supposed to attach the hose from the T, and then attach another hose to the gauge if there isn't anywhere to run the hose from? lol
The sensor comes with a wiring loom, hopefully i don't run into trouble hooking that up..
no hose goes to the gauge, from what i see, hose goes from t to the sensor, then one plug goes into the sensor, and another into the back of the gauge, then the wires are wired up to the car... thats what it looks like
Got it installed today! wiring was a bit all over the place lol, but done in the end. I'm not sure about its accuracy because it's basically reading the same (but showing im boosting a bit less) than stock.
Need to find a trusted gauge to calibrate it next to lol.
cheers for the info guys.
P.S is it just me, but whenever i'm working on my car taking stuff apart and putting new stuff in, something that was in my hand 2mins ago just goes missing for like the next 10mins? lol
sorry to bring this thread alive again, but it's regarding the guage. it works fine and everything, but the one thing i didn't get time to hook up was the light switch wire.
So i tried hooking it up today and tapped into the cigarette lighter light, so that the backlight of the gauge would only turn on when my headlights are on.
HOWEVER, for some reason when i turn on the light (one click to turn the parker lights and interior dash lights on), the fuse blows up!
The 10A fuse underneath the bonnet that's labelled on the fuse box cover as "Head L RH" keeps blowing up. I've replaced it 4 times now, and i don't know why it's doing that :( Shouldn't tapping into the cigarette lighter light work? :s
P.S I've tried opening up the steering wheel column and finding a wire to tap into when the light is switched on, but the looms are crazy tight and i can't access any wires.
Have you tried putting an ammeter in the circuit to the gauge's lighting wire to see what current it is drawing when you give it 12V? It might be drawing an enormous current due to being f**ked.
no i haven't tried that. That would explain it though... if the amps are too high, would soldering a few resistors together fix it up?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
