Hey guys,
New to the forum! New to skylines as I've been a Holden fan since I could afford one. But I recently moved to QLD (approx a month ago) and want to get into skylines as I've driven one recently and love them! I have no idea what I'm looking for (Absolute n00b), what price is reasonable etc. Any input on this:
http://www.gumtree.com.au/s-ad/mount-louisa/cars-vans-utes/1995-nissan-skyline-sedan-wanting-quick-sale/1008858190
Would be greatly appreciated!
Cheers guys!
https://www.sau.com.au/forums/topic/415626-should-i-buy-this-r33-gts-t/
Not as common as 33 coupes, so a little different, 4door practicality, RB25DET growl and go.
Win, win, WIN !!! It's a series 1 and you can put series 2 taillights on if you wanted.
^^^ Some Food for thought? ^^^
Edited by Not a Pulsar
17 year old car might be good or might be a money pit, is there a work shop in your area that knows Skylines ?
Does the car have service history, where was it serviced.
Can you take it somewhere to get it checked out, put it on a hoist, do a compression test.
It will cost you a bit but its good peice of mind, the owner should only complain if there is problems with the car as it will cost him nothing but a little time.
I might still go bang though, or it might not !
Sorry, but thats how it is.
Your rear end looks good :P haha!
But mlr you're more than right on that, didn't even think about those things, you would think that if it has a RWC you're good to go, but that's not the case, maybe there's a reason why it's so cheap, yet to call the seller. I don't know how to go about it, buy a stock skyline up to 8k, or spend 15k for something modded and well looked after. For me it's a toss up lol.
Again, thanks for the insight :)
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
