Hey everyone, after a lot of thinking I am ready to put my 34 up for sale.
Black 1998 r34 manual coupe.
99,000kms
oil/filter changed every 5000ks
extremely looked after, no stupid driving etc
BC BR type coilovers, done about 3000ks
High flow air filter
Basically brand new rota grids, 18x9.5 +20 all round with kics lock nuts
Full polk audio sound sytem. Splits, 12'' sub, both run off separate amps
Pioneer fold out touch screen audio interface
Located in Kingaroy, south east qld, perfect P platers car. Not too far from brissy or the coast
Second owner in aus, Imported in 2011
Car will have its 100,000km service done (timing belt, water pump, spark plugs, oils, all belts, filters, etc)
$13999 ONO with wheels and coilovers. May be able to sort something out if these arent wanted.
Cheers, Luke
DSC_7743 by M4GICK, on Flickr
DSC_7752 by M4GICK, on Flickr
IMG_0562 by M4GICK, on Flickr
IMG_0563 by M4GICK, on Flickr
IMG_0559 by M4GICK, on Flickr
DSC_8434 by M4GICK, on Flickr
https://www.sau.com.au/forums/topic/415635-r34-gt-manual-coupe-p-plate-legal/
  • 1 month later...
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
