I've just started my RB26/30 build and i'm looking for advice if its worthwhile enlarging the sump and adding the rear head drain.
The engine is primarily a street engine with very occasional 1/4 mile and track use. I plan to limit the revs to 8250-8500rpm. I already have sump baffles, oil restrictor and a N1 oil pump, and a large oil cooler. I was going to add the sump and head drain but now i think the money could be best spent on other things.....HELP
For the $300 or thereabouts the rear head drain will cost why not? If that was the one thing that prevented your engine spinning a bearing would the $300 be well spent? Shit yes!
With the sump, cheapest you'll get out of it is about $800 for a "proper" extension. Again, a small price to pay compared to the price of rebuilding an engine!
Preventative measures (as opposed to performance boosting mods) are a bit like car insurance, you hope to never have to use it but FK you're glad you had it when shit turns bad!
Money spent on oil system is never wasted. I smashed my N1 pump first time I drifted my RB30/26.
I made my own head drain from 1inch bsb brass pipe fittings (local hardware store, just needed to borrow a tap to thread the head) and 1inch ID red oil line. And upgraded to a Tomei pump (removed one spring to get pressure back to normalish for street). Welded a return into the home made sump and never had another oil warning light again.
Pretty much, everyone ops to go the tomei, greddy, nitto pumps for stronger materials that are used while building these pumps which are stronger then the n1 pumps that are always breaking, on idle and under heavy loads,
I went straight to a nitto pump as I didn't wanna risk breaking a n1 pump and rebuilding my motor again
N1 pumps don't just 'break', more than enough info on the pages of this forum to work that out.
I've run them for 7 years on 3 motors, never broken one and i bash the limiters in them without fear.
Mine "just broke" so I disagree.
And I NEVER limiter bash. My engine had only done about 15,000kms with that pump in it before it went. It had never been on a track and only the odd caning (so I'm told!).
You obviously got lucky. There is some sort of issue with them be it the quality of the material or a flaw in the casting that makes them weak.
There's no way I'd risk a standard N1 pump again, it's not worth it. This time I've gone N1 pump with Reimax gears so fingers crossed......
(so you were told), that sums that up - you don't even know!
I didn't get lucky, 60,000kms over the 3 motors says so.
And then what about the rest of the motor? Did you have it checked or just blame the pump?
Was properly balanced? Crank snout and engagement 100%?
Sounds like you don't know that either - so how you can say it "just broke" is... interesting. :)
Ok legend, while there is validity in some of what you say, you need to learn that just becase something hasn't happened to you, doesn't mean it doesn't happen! Whenever someone theorises an issue you have a tendency to ridicule them because "I've..never broken one" etc, etc.
The engine in my car was already built so no, I don't know exactly what was done. It was built by a reputable engine builder/tuner in Brisbane so I can only presume it was done correctly.
I also like how you make your own legendary presumptions- "And then what about the rest of the motor? Did you have it checked or just blame the pump?
Sounds like you don't know that either - so how you can say it "just broke" is... interesting."
I could go on but it seems it would be a waste of time. You're the "most viewed admin of all time" so clearly the oracle of the RB. :action-smiley-069:
The problem is the harmonics of the stock 30 crank during fast changing from low to high revs, a billet crank is supposed to be better and will take more revs without trying to lunch the pump.
From what I understand a stock balanced crank will be fine with a Tomei pump up to around 7500rpm on a fast reving motor, over 7500 is possible but you are getting over the happy zone, apparently a billet crank can take alot more abuse, how much I dont know but Ive "heard" of 30's being reved to around 10 with one, fact or fiction, I dont know.
I have a 25/30 with a Tomei pump, limited to 7500, I shift at around 7200 though as this keeps me in the sweet torque range and limits the abuse, I donot race for sheep stations so reving beyond that on a stock (albeit balanced) crank is something that does not interest me.
Of course there is validity - I wouldn't be saying it if it wasn't there.
Because a pump fails - does not mean it's the actual pumps fault. Think a bit bigger than what you see before you. It's like saying it's a tyres fault for blowing out, but the actual cause was a nail that deflated it, leading to a blow out.
Given you have no idea of the motor build and it's treatment before you got it, sounds like you didn't have it properly inspected afterwards... And as a result cant confirm with any reasonable certainty there is nothing else at play here - you cannot for a second say it's exclusively the pumps fault. The entire design is flawed, hence the Tomei is the "best" solution on a budget... EVen then you can even kill a Tomei pump if you try hard enough or the build overall is poor (users have here before).
Yes to the bigger sump. There is no evidence that the "head drain" actually does anything. If you are still at the building stage drill out and relieve the oil returns and drill and tap one or more holes as high as possible for sump breathers (running to a catch can, not the head. 8,500 is a lot for an RB30 - they can be made to rev to 10,000 but even at 8500 you will need a quality damper and everything well blueprinted and balanced.
Have you looked at the inside of one?
Compare it to the inside of a brand name upgrade... its very easy to see why they "Just break."
When an engine that normaly rev's underload from 3000 to 7000 rpm in a few seconds suddenly does it in one second but still moves the same thickness and volume of oil with the same thin cogs that a stock oil pump has (N1 or not). Having the right oil restrictions to the head is always a very important thing and enlarging oil return paths is definatly going to lessen the requirement of a head oil drain.... However if you look at the budgetless big race RB's in Japan you'll see many combos of oil drain and even bigger pumping systems. I'm yet to see a pro car with a stock or N1 pump.
This is a street engine, its not going to be a 1000hp pro car. I have read that running a crank case evac system is more benifical than a head drain ( which seems to be fashionable these days ). I understand that N1 pumps are a O.E mass cast item but if the weak point is the gears then a crank collar and billet gears should fix or lesson the chance of breakage. i will also drill tha pan to allow oil to drain back to the pick up area
Crank collar and billet gears will definately help, mandatory as your car is a 32 with no doubt a short snout crank drive.
I would highly recommend getting the collar custom made or at least try to get one that is matched to your pump. Every 26 crank snout I have seen has wear on the leading and trailing edge of the drive suggesting that there is clearance between the snout and the pump drive. No doubt with the harmonics causing a "rattling effect" of the pump on the drive this speeds up the wear on both the drive and the pump.
interesting shoota_77 i was thinking all off the shelf parts are the same, but having one machined to suit my specific parts makes sense. Do you have any recomendations on how to use? i'm located in W.A but i can freight my parts through work if needed.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
