Every company that makes the collars has their own method and measurements that they're working off so will all vary to a degree. It only needs to be a few thou different to make the difference between being an interference fit and "loose".
In an ideal world you would take your intended pump drive inner ring to the machinist and have him match the new crank collar to the inner ring to be a perfect fit. Even to the point of having to slightly heat the oil pump inner ring when re-installing the pump it so it slides on. This would potentially cause issues though when time came to remove the pump as it could get pretty well locked onto the crank collar once a bit of rust formed. Theoretically you shouldn't have to pull it apart too often though.
That's entirely my own logic so feel free to rebuff!
I've started my rb30/26 build (well sorta) and I'm going stock (new) 26 oil pump but with reimax billet oil pump gears/nitto crank collar
90% street driven we don't see the need for anything more
Yes. The N1 pump has smaller gears than the standard pump.
I can't recall the actual measurements but it's about 5mm or so difference.
You need to order the right gears for the pump you have in other words.
Spend your money on a good set of pistons with good rings that will actually seal...The RB oiling problem is 90% excessive crankcase pressure (too much blow by) and 10% too much oil flow to the head. You need to fix the problem at the heart of it all!
Putting on extra crankcase breathers is only another band aid fix. Which does work fine though. If your engine is already built or bought, then adding the appropriate breathers is your only real choice.
exactly, the problem isn't getting the oil to the sump it's letting the air out and in an ideal world piston rings that seal perfectly would be lovely but not everyone can afford them, so crank case/sump breathers are a good solution/alternative
given the design of the head (26 anyway) the "rear head drain " is more just a breather and even though some oil does go down it the air it releases from the bottom end is its main benefit
as Shoota_77 has said the gears in the stock pump are bigger and IMO would be the choice of OEM pumps if you are going to change the gears to the Reimax ones and shim it for a bit more pressure
Can anyone confirm if the cp piston kits come with optional upgraded "high boost" piston rings??
When my mate did his rebuild they asked if he wanted the standard rings or better ones for extra $150 or so
I cannot find much info on these different rings
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
