Chasing a r32 gtr for around the 10-12k mark I know hard to find for that price with a good car but after one with a straight body good interior something that runs perfect not worried if the paint isn't good let me know what you have or if yOu have one a bit dearer but can take good wheels or something off to bring tge price down please txt cheers 0403236841
https://www.sau.com.au/forums/topic/415652-wanting-r32-gtr/
Put it this way. i paid 13k for mine and the engine blew up in 4 months. 18k later its a fully resprayed/rebuilt gem. Save up the extra cash mate and get one thats worth buying. Just my 2 cents.
Edit: im picking mine up today with the new -7's installed!
Edited by Anfanee
https://www.sau.com.au/forums/topic/415652-wanting-r32-gtr/#findComment-6672054
Goodluck, i hope you dont go through the pain i had too. It's going to hit a 20k rebuild in january... Mine WAS stock till it went puff. head gasket, cracked pistons and shattered valves. Had to do a complete bottom and top end rebuild. Hence i went all out and put slightly bigger pistons in, upgraded the fuel system etc. had it back for a week and blew a turbo (i was a noob and didn't bother replacing the stock turbos yet) as i didnt have the cash to replace them at the time. Back in it went. Put -7's in it. Picked it up last night. Still running wastegate as im still running the engine in but should be a bit of fun when i can give it a bit..
https://www.sau.com.au/forums/topic/415652-wanting-r32-gtr/#findComment-6673374
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
