Hey guys, First post so go easy on me haha..
Have a Forged RB30det R32 making 320kws with all the goodies etc etc... Had a problem with an oil pump failure which has lead to big end bearing damage and a possibly expensive rebuild :down:
Long story short just wondering if anyone has any recommendations for a good engine rebuilder in NSW or if anyone has had a recent rebuild from somewhere and what they've paid. This will be my first engine rebuild and im not sure what to expect pricewise.
Cheers
https://www.sau.com.au/forums/topic/415658-best-rb30det-engine-rebuilder-nsw/
Nsw is a big state, it would probably help if you gave a little more detail of where in Nsw u are.
Get a nitto or tomei pump for the new engine, that will prevent u having the same issue in the future.
Depending on what u are lookin at spending it may be cheaper to import a short block from RIPS in nz.
http://www.ripsltd.com/products.html
it also depends on how much you can do you're self and how much damage is done, spun bigend could mean you just need to regrind crank, new conrod and bearings, fairly simple job, or it could be new crank line bore and hone of block as well as new conrod and bearings
contact Gerg_R31's on here and have a chat with him, he is an engine builder and specializes in RB30s and is located at Liverpool/Moorebank
this is his build thread http://www.skylinesaustralia.com/forums/topic/374496-gerg-r31s-na-rb2630de/
This. plenty of experience, no messing around and will tell u what u need to know. Quite a few members have had engines assembled by Greg.
    • Sorry the pictures suck. So hard to get camera and light in there
    • One of the first jobs with the E39 is making sure the tailgate stays up. In BMW fashion they made a little cavity under the roof to hide the dampers rather than putting them down the side like everybody else.  As you can see I have these little cavities that house the dampers. When I cleared one out and vacuumed as much crap as I could out of it I noticed a fair bit of rust. The cavity is bone dry, even after all that rain we had only a few days ago so I'm assuming that whatever allowed the moisture in is fixed but I'd like to treat the rust in there.  I was thinking of just blasting it full of rust converter but I didn't know if this would be beneficial considering I can't actually get in there to prep anything.  Maybe there's a better product?  Thanks guys
    • Had a few skylines over the years anyway bought this a few years ago for skidz i think it’s been around these traps for a while anyway I plan to thrash and trash and I assume it’s going to send me broke good times
    • The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed. When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi. When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework. A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be. So, yes, your diagrams are correct.
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
