i have noticed that my drivers side headlight is crystal clear, my passanger side has always been really cloudy. today i went to the car wash, as i was cleaning it i noticed the passenger headlight was perfect. after the car dried though it became even more cloudy. any ideas or opinions??? your help will be very much appreciated!
https://www.sau.com.au/forums/topic/415674-1-headlight-cloudy/
Many times over this has been covered.
Search for "yellow fever".
or just try, cut and polish, polish, toothpaste, brasso or there are products available especially for this.
Here are some links that might help you.
http://www.skylinesaustralia.com/forums/topic/249906-yellow-fever-restoring-r33-and-r34-model-headlights/page__hl__yellow%20fever
http://www.skylinesaustralia.com/forums/topic/406646-magic-headlight-fix/page__hl__yellow%20fever
etc...
If it's actually moisture, pull the bulbs and get a hairdryer in there.
If it's oxidisation on the inside of the lense, aside from going to the trouble of pulling them apart etc...
replace them or live with it.
yeah i agree im a panel beater and many people ask how they can fix it polishing it is just quick fix you will find it will come back and some times worse it comes from the protective layer on the plastic wears away and sanding it will only take more layers away and as for the water on the inside of the head light well you may have a small leak in the headlight do as notapulsar said and dry the headlight out and look and see if you can find a leak
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
