Hey guys I had a search and couldn't find anything so just creating this.
Does the series 1 r33 front bar restrict airflow to the front mount intercoolers/radiator or is it such a minimal thing you would not need to worry about?
I have seen plenty of cars still running the stock front bar with the part cut out to show the cooler and others with just the stock look.
https://www.sau.com.au/forums/topic/415677-front-bar-restricting-air-flow/
I questioned my number plate blocking my intercooler, but really it must be very little, mine pulls like a freight train no matter what, hot day, number plate half blocking cooler, whatever.... ya cant stop a gt3076 kicking ass lol :)
Would think its minimal as in shouldn't make much diff as there are plenty of s1 r33s getting around with decent power
Not saying it means you can't get power
But would you think it could possibly make more power with the whole intercooler getting air
No it won't stop it making good power, the air flow through the front has nothing to do with how the car makes power.
What it will effect is heat soak.
It will restrict air to the radiator and FMIC, depending on your type of driving will depend on if you notice anything.
Personally, even on mild built track car, I wouldn't worry about cutting it out.
So heat soak doesn't effect power...?
If air to the intercooler has nothing to do with power then why do we all run intercoolers
Unless you mean that you can drive in a way that the car doesn't get heat soaked there for it isn't effected by the airflow
heat soak obviously affect power that is why your car drives like sht in a 50 degrees day compare to a 15 degrees days.
The cut out on the front bumper bar do affect heat exchanging, after squashing a 600x300x75 cooler kit into my s14's stock front bar the edge that is covered is much hotter then the center that is exposed. Got rid of it and installed a open mouth vertex, that worked out much better.
Yep heatsoak definately will have an effect on power, no question at all there.
Just make a air guide up, and block the edges off from the front bar to force the air through.
It will also help cutting, but once you cut - you can't go back :)
This was my main concern also the fact not having a trust worthy reo bar as support.
Might see how I can create something to flow up in there or possibly a cheap 2nd hand front bar
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
