ill confirm it for you, im 100% on this, i looked into it a fair bit. it has to be completely enclosed to avoid a fire hazard because the pod filter is made of paper after all. to avoid the paper catching on fire it needs to be completely enclosed.
i really dont get the point of those half assed covers on justjap and ebay that only cover the top of it.
so does this mean if you have the stock air setup with a metal intake pipe, the induction sound will remain?
dammit. ok , so any links to fully enclosed boxes for pods as I want to retain the bov sound
thing is, if you do get a legal fully enclosed pod filter cover, there probably wont be any sound, similarly to the stock airbox.
ahh im going crazy without the sound, contemplating pulling one of the pipes off the BOV valve off, to get a bit of a flutter :P
Hmm... well next thing is...how knowledgeable is the average cop on the legality of a fully enclosed box?
If they just see a cover over it (that they cant remove at the time) are they likely to look beneath it or even know that its supposed to legally be fully enclosed?
Not all states have exposed pods as illegal. Qld doesn't (just has to be secured with a bracket). So enclosures like the just jap one work well as heat Shields, which is the point of them. A pod in a fully enclosed box often won't flow any better than a decent panel filter in the stock box.
Pods don't need to be boxed in the ACT either, just secured.
Pods in the engine bay are sucking hot/warm air unless shielded.
Noisey Bovs are noisey due to turbulence, therefore not moving the air as efficiently as they could.
Personally, I would rather a stock box knowing the air is as cool as it can be and a plumb back Bov that's quiet is doing it's job well.
Function over fashion.
The stock bov makes a fair bit of noise when it isn't muffled by the airbox. Pull the snorkel off the stock box and you will hear the stock bov a bit. It isn't louder because it is more turbulent, simply less muffled. The same goes with having the stock bov and a pod. I made an alloy heatshield for my pod and all the intake and bov noises got louder because it acted like an echo chamber.
As for air temp, a decent intercooler will negate the higher air temp to a certain extent. And then there is the argument of air temp vs air volume. If you are at a power level where the airbox is becoming a restriction, an exposed pod will work better than an airbox. Obviously the colder the air, the better, but it has to be within reason.
well with laws and performance partially aside. is there any way to get the best of both worlds. which is having sound as well as having a stock looking air system. removing the snorkle alone didn't increase the sound noticeably.
I had no way to fit a stock air box on my set up... So pods were the only option. I will be getting these boxed, More so a cover for the top & sides and a Cold air intake feeding from the pods from the bottom of the box
so , have we come to the conclusion that as long as you have a heatshiled cover of some time , the majority of cops will not defect you?
Also , there is no way to keep the bov sound while having a pod legally ( it being fully enclosed) ?
Just move to QLD or ACT=Profit.
lol , yes pack up and move purely for the bov sound...
just get the cover man..
check my other thread
as long as your car isnt to loud , its isnt ridiculously low and you arnt driving like a total d*ck , you should be ok 99% of the time
at the end of the day you drive a skyline and if a HWP wants to defect you , he will.
okay, so i've finally gone crazy without hearing my turbo for way too long.
I've decided to make a box to hold the pod filter in, there are heaps of images and threads on this everywhere, but i've got one main question.
if i did make a box to hold the pod filter in, would this box muffle most of the blow off sound that came from the pod filter?
and what material/metal is best to allow most of the sound to be heard?
wish i could just make one outta aluminium foil :P.
anyone have any recomendations on types of material to use, e.g which metal? something thats not too hard to get, not too expensive, yet is thin?
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
