Recently did some work to my GTR, and now my alarm system is no longer working >_<
I am unsure of specifics as it was already on the car when i bought it, but i know it is a viper system.
None of the features work, It seems the alarm is not physically on.
Just had my car dyno tuned with a apexi power fc, would installing the power fc had some effect on the alarm or could the power just have gone?
Any advice on where to start trouble shooting will be great,
Also note - the alarm has a switch to enable and disable remote start, flicked it in either position and it has no effect. Receiver just beeps at me as if its trying to send the signal but it never gets received.
I take it if i follow the cable from the speaker/siren or the remote start switch toggle it should lead me to the alarm system itself?
https://www.sau.com.au/forums/topic/415702-car-alarm-just-stopped-working/
dealer can do it. that said I *MAY* have the book for it at the shop. wont be until monday though.
I have the guide book for 2008 , 5901
Shoot me a pm with your email addy to send it over
Random question - My car siren/speaker kept going off randomly. Sometimes it would be sweet for day's, othertimes it would just keep going off. So i ended up disconnecting it.
Now, is it the fault of the alarm or the siren itself (why did it keep going off?)
if its just the siren, can i just replace it and job done?
Or do i need a whole new alarm
If the alarm siren is more then 2.5-3 years old or the car battery has been run flat during that time
The internal siren battery could be faulty and needs replaced , if the siren horn has a stamp on the nose 515esp or 515r it's more the likely due for replacement , the new one is smaller and lots louder way more annoying for crims lol
the above models fail at the 3 yr mark in most case or leak around the key if gasket is missing
do not disconnect
Car thieves favourite trick is to annoy you by setting off your siren often till you shut off the alarm or cut the siren off , then bang they steal your car!!
don't fall for it
Alarms rarely false once setup right
Could be a bad sensor or door trigger as well
How many beeps you can figure it out from that?
New sirens run 60-120 bucks retail depending on where you buy it
You must have battery backup model at min
Did you get your remote working ?
Edited by Carbon 34
The siren is stuffed, the key to turn the siren on and off just spins freely all the way around!
If I can just connect a new siren to my alarm system that would be the best bet. I opened it up at one stage and there some burn marks on the PCB. So something had shorted/fried. I'd say water damage. The alarm was installed 3 years ago from august. When I did my stereo install, funny enough I didn't find the brain, I am hoping its a good quality install but who knows...
Remotes are still not working :(
Just spoke to the chap at auto barn, said the most probable cause would be a blown fuse, reckens vipers rarely loose their sync. Here's hoping I can find where the fuses are and check them
Haha did I call the alarm date or what
Check the siren model it's on the horn nose middle
A common problem on the ESP was the key spins and rips off wires steam kills the siren -slowly goes nuts
Yes you can update with a new much better siren easy enough if you know how to solder properly?
Any aftermarket installs after alarms seem to end with a dead alarm unless a security installer does it - about 80% of the time lol funny how that works
Dealers are notoriously bad
I can't disclose the fuse info online but the original install people could ? just don't go nuts digging around or it could cause more issues
True if the alarm isn't locked with bit writer Sync is only issue after dead battery but picks up the code quickly after replaced or charged again
Is your antenna ( alarm still plugged in and not cut?) that will stop the remote range to mm
I like to think i can solder well, did a few console mods back in the day.
Just found the brain of the alarm, looks like a pretty shonky install, nothing is neat. I am sure its a challange in itself to keep it neat, but I recken i could have done a better job :\ Little bits of electrical take here and their.
Checked the main fuses, none are blown.
Was trying to get it resync'd but hard to tell if i am in the right mode due to the siren disconnected, my valet switch was flashing which is a good sign meaning my alarm has power.
But just unsure how to pair it, the instruction's are not making much sense to a simpleton like myself.
Antenna wire looks all good, all wiring looked ok as in not damaged.
Setup shop on melbourne will u troy far out ha ha, I am not typically keen letting the blokes at autobarn touch my baby..
Edited by Booki
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
    • OR, Tell the Motec to STFU, you said shift, so try shifting! But then yes, I agree, more sensors needed to. Put either a wheel speed sensor, or a diff speed sensor on it. Then get an input shaft speed sensor too. (I say input shaft speed, and not engine RPM). This way, you can now also log and see if the clutch is slipping (RPM, vs input shaft speed), and you can calculate gear (Input shaft speed / Output shaft speed). At least then if the gear position sensor fails you have a backup. And realistically, the Motec should only worry about what gear you're in for the parts where I'm assuming you have some power management strategies in it for the lower gears. (IE, lower boost, maybe different throttle curves, different ignition curves, etc etc). But it should stop it shifting. Pull the flappy, that f**ker should just attempt the motion! Heck, even on a sequential like on a motorbike, you can keep trying to kick it up a gear all you want, the physically part of the box takes care of not being able to loop the whole way around the box! Only part you'd have to worry is how it gets to reverse.  But that's on the driver... An R32 shouldn't be so smart as to try and override the driver on a gear shift
    • Yeah, nah. Anyone not putting the absolutely largest battery that will physically fit (ie, NS70 X) is not thinking straight. the NS70 X is close on double the capacity of the "stock" unit.
