Hi all
Surplus to my requirements is this CIGWeld Easywelder EC stick welder. It's rated to 140A so is good for welding up to 10mm, but can easily weld 1.6mm too (even thinner if you knw what you're doing, but I never welded anything thinner than that).
I now have a MIG and TIG (which also doubles as a Stick welder) so this one just sits on the shelf gathering dust.
The welder is about 15 years old, and has been used for light duty home fabrication (shelving, work benches etc). I haven't used it now for about 6 years, although I fired it up this morning to test it and it still works a treat.
These are a good portable welder (they were some of the first "caddy" style welders to hit the market around 20 years ago, and at the time were the ducks nuts. I remember the boilermakers at work raving about them). It's served me well, but I no longer have any use for it.
There are no accessories included (gloves, helmet etc) although I might be able to find the original welding mask that came with it. For the price of LCD auto darkening helmets these days, I wouldn't bother with the old school stuff anymore though.
Note there is some insulation damage to the earth lead, as shown in one of the photos. It's been taped up with black tape for a good 10 years, although I peeled the tape off it this morning to show the damage. Since it's on the earth lead, it's hardly likely to cause a hazard, even if left uncovered.
I'm too lazy to post specs for the welder, but I found the same model for sale on Gumtree (http://www.gumtree.c...r-ec/1010815735). Note that one is NOT mine - I've just posted the link in case someone wants more specs on the welder.
The welder has a 15A plug, and comes with the work piece / lead as shown in the pictures.
Looking for $50 for the welder - pick up only from the Gold Coast.
PM if you're interested.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
