Hey guys,
i've had my r32 GTR for about 4 months now... and loving it! I do however have a slight issue with the ac/heater. even with the AC off, i have stupid amounts of hot air coming through the foot vent... bearable in winter if its <10c; however, anything over, windows MUST be down and its pretty uncomfortable, i just put up with it, but i needn;t comment on female passengers opinion.
how the hell is the vent blowing so much hot air with the ac off? (ac needs re gassing but thats another thing completely) any ideas?
Thanks,
Dan
i find on my 33 it does the same thing, my temp control doesnt change have to fix it,
but it wont allow hot air in if i make sure i have the recirculate button on
dunno if it would be the same as yours though
Thanks Luke, ive tried that though. (and ac not gassed so blows hot air regardless of temp set :/)
i have not tried turning it off with the recirculate function set prior to switch off.. ill see if that does anything
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
