Get a regulator instead! way cheaper than buying injectors (new or second-hand)
there are many guys running 230rwkw with std RB20 injectors and an aftermarket reg
I bought mine from Envy Imports in brookvale. they carry the Sard range and are heaps cheaper than anyone else.
Tell them Ben sent you and you demand a discount because you said my name! haha
their number is 99074144 they arent open this weekend tho. ask for Herman
Gday,
Had a power run done today, got higher then what i was expecting.
Mods:
R34 turbo
Trust FMIC
Trust Pod
R33 GTR Fuel Pump
EBC - 10psi and 14psi
Result:
161.3rwkw on 10psi
189.4rwkw on 14psi
AFR was starting to struggle on 14psi, what could fix this?
great result mate
stock exhaust??
  • 10 months later...
personally I don't think that is too lean. providing your timing is not too far advanced, and the car is not pinging you shouldn't have a problem. The AFR is still around 11.5:1 where the car would be coming up onto boost and making peak torque which is often where some detonation occurs. 12.2:1 up top is not too bad. possibly be nice to improve it to say a flat 12:1 but to do that I'd recomend getting some sort of programmable ecu.
Very nice,
You can really see it come to life when its on 14psi, I wouldn't worrie about the leaning out as its just going over 12. But it wouldn't hurt to get a RRFPR installed to keep that fuel up their.
All you need now is a PFC and you should be able to level out that AFR line to about 11.5 - 11.8 and wind some ignition in and you should see close to 200rwkw's on 14psi :D
Gday,
Mods:
R34 turbo
Trust FMIC
Trust Pod
R33 GTR Fuel Pump
2.5 inch turbo back exhaust
Result:
161.3rwkw on 10psi
189.4rwkw on 14psi
Hey mate so your not running any kind of aftermarket computer or any piggy back chips on your stock ecu?
very nice result btw
