Guest two.06l
If youve hooked it up properly, you should be able to cut your nut, and then once the switch it turned back to "4WD" mode, it re engages 4WD and ABS once you come to a standstill. I.e Not moving.
well wish it would so i could perform burnout before a run but it does not go back into 4wd until ign is switched off and then back on
https://www.sau.com.au/forums/topic/41577-4wd2wd-gtr-switch/#findComment-874203
Guest two.06l
It is setup wrong if it wont go back to 4wd when the car stops rolling.
pulled fuse in fuse box taken both sides of circuit into console by extending wires put inline fuse into circuit and inline toggle switch.still does not work.has anybody set one of these up to actually work and if so pls respond.
https://www.sau.com.au/forums/topic/41577-4wd2wd-gtr-switch/#findComment-874439
