Hey guys,
My RB25DENEO in my R34 has cut out while driving twice over the last two weeks and the engine and oil light have both come on each time this has happened. Once i come to a stop, i can turn the engine on and drive away just fine.
I changed the oil after the first time it happened as it was very low and the car ran smoother but it happened again after this.
I am planning to take it to a mechanic today, but was curious if anyone had any ideas here?
Thanks a lot.
https://www.sau.com.au/forums/topic/415772-engine-cutting-out/
had same issue on a 33, check you box oil level, mine was a little low due to a split line going to the radiator.
basically i would accelerate then come of the accel, and the revs would drop right down and engine would cut out.
(this also happens if boost pressure is not plumbed back into the turbo, but your natro so cant see it being that)
How about connection up to a consult cable and reading any fault codes...
My auto 32 did this cutout thing not long ago, I managed to limp home and the only fault code was 12: air flow meter
Followed the tutorial and re-soldered the pins and hey presto, not more engine cutting out.
Plugged it in last night and no fault codes detected. however, my timing was going all over the place, jumping from 4, up to 17, then down again etc. then it had brief moments staying on 15. Could it be the CAS?
yep same issue as mine exactly....... have you reset the ecu?
Yeah, i reset it 2 days ago. Not sure if it helped at all. Car hasn't cut out since, but im not convinced a ecu reset has fixed it? I just see how it goes.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
