Hi everyone,
Had this GTR for 2 years as a restoration project. Finally got it complete but think old age has gotten to me and am looking for my next challenge.
Interested in buying a euro or continuing down the path of a JDM car but probably something more daily (Accord, etc)...
So I'd be happy to do trades/swaps but it MUST be for a car within the 8 years... preferably with either cash my way but we can talk.
If not, the price is 25k
So the car...
All modifications done within last 2 years
Performance:
Rebuilt R33 RB26DETT (OEM specs) – Receipt will be provided (Completed Mid 2011)
New thermostat (OEM)
HKS Cam gears
ARC induction airbox
2 x Greddy T517Z turbos
HKS Type R intercooler with Greddy hardpipe
Split dumps
Mine’s equal length front pipe
Fujitsubo Legalis 304 cat back
HKS EVC 6 boost controller
HKS Turbo Timer – Type 01
Power FC and hand controller
HKS 600cc injectors
Nismo Fuel pressure regulator
Cusco catch can
C’s Short Shifter
Nismo Braided Clutch line
New OS Giken Triple plate and Flywheel (1/12/2012)
Nismo Clutch Slave (24/11/2012)
New Master Clutch Cylinder (1/12/2012)
Handling:
Greddy Type S coilovers
New bushes all around
HICAS Lock bar
Rebuilt driveshaft bearings (front and rear)
Cusco Front Strut bar
New rear diff
Endless CCX front and rear pads
SSR Type C – 17x9 wrapped in brand new Kumho KU31’s (25/08/2012)
4WD Wheel Alignment (7/09/2012)
BBS light weight wheel nuts
Cosmetic:
Full respray (Everything including engine bay) in R35 GTR - Ultimate Opal White – Receipt will be provided (Completed 25/08/2012)
N1 front bar with genuine N1 ducts and intercooler air guide
Genuine Carbon Fibre Exhaust Shield
R34 GTR valley cover
PIAA Carbon Racing wipers (Brand new – 27/08/2012)
Genuine R35 ‘GTR’ badge
Immaculate interior with brand new dash and OEM steering wheel (no bubbles)
Brand new leather shift boot and handbrake boot (black with red stitching)
Retrimmed genuine Recaro SR3 with Recaro low rails
Tomei 320km Speedo Cluster
Nismo GT500 shift knob
Full set of brand new Nismo Carpets
Kenwood 2 Din touch screen with Nav and Bluetooth installed (15/12/2012)
Alpine Type R series 2 speakers (24/11/2012)
Nismo Radiator cap
HKS engine oil cap
HID headlight kit
VIPER alarm system
All fluids flushed and replaced 2 years ago.
Serviced recently with Motul 8100 and Motul Inugel coolant (Last service 25/08/2012)
Recently had Redline Fuel System Cleaner (29/08/2012)
Redline Lightweight Shockproof Gearbox fluid
I've only got one word "Amazing" This has to be the cleanest modified 32 gtr on the market! That paint job................. :yes:
I say it's way to cheap.
Good luck
Dave
Thanks Dave, I really went all out no bars held.
The paint job was a full respray (So everything including the engine was taken out for the respray).
Hopefully the new owner will take care of it as well as I have thus far... only Zymol wax on that job
Edited by R34_Wong
  • 1 month later...
  • 3 weeks later...
    • Also, the cause of fuel spills and smells from the top of the tank is almost always the rubber hoses that are up there, not the tank seal.
    • 1. No, as you say you can remove the connectors and fuel lines. Before you do make sure you remove fuel pump fuse and crank the starter a few times to release pressure, and also loosen the fuel cap (just in case the tank is slightly pressurised) as it will pump out the lines otherwise 2. Not necessary but you are right, if it is the factory pump it is at risk of failing after 25 years....Changing it is not hard but potentially not trivial as you have to make sure you have the right pickup/sock for the pump to suit the tank, need to make wiring connections (crimped butt connectors would be fine) and have to mount/adapt the new pump in the right place in the cradle. Not impossible but don't start the job if you aren't confident. Also, the plastic nut that holds that seal in place can be really hard to remove. If you don't have a fuel nut removal tool it generally requires a big screwdriver or similar to bash the ring around a few times before you can get it by hand. Also the fuel lines can be very sticky on the tank lid fittings, hose removal pliers can help or if not twist the hose on the fitting (eg with linesperson's pliers) to break the seal before you try and remove it. Finally, mark the feed and return hoses so you don't put them on backwards and seal them with an m8 bolt to stop crap getting into the lines while working. Add a little grease in the threads of the plastic lid when you go to do it back up as a gift to your future self, and make sure you put it on evenly/not cross threaded.  Having said all that, most likely the lid just needs to be either tightened or removed and put back on without being cross threaded...the seal itself is usually pretty good.
    • Another weekend and another project I have questions about.... I bought a fuel tank sender O ring to install on the car because I'm quite sus on what I've got now.  1. No "whooosh" sound when opening fuel cap 2. If I fill up full tank, there will be a small leak under the car and it comes from the top of the fuel tank, dripping along the side. Stops after a short while 3. Hot days = 50/50 chance to get high as a kite inside the cabin if the car was in the sun for too long This is what I bought: https://www.amayama.com/en/part/nissan/1734279900 My plan was to just replace the O ring but I've got some questions: 1. Does the whole fuel pump assembly need to come out for me to replace the O ring?         Or, could I unplug all the connectors and fuel lines at the top, take off the twisty part (17343) and put in the O ring from the top?  2. Is it a very common thing for everyone to just change the pump whenever doing this?        I see the Walbro 255 gets thrown in a lot but I've got no issues with my pump so far. When I did the tune, I asked the guy to check my fuel pressure and he said there were no issues too. But is it just a good idea to change to the 255 anyway as the old unit may have been in there for so long? The 255 seems to be a direct fit for GTT (I got no soldering iron)
    • Normal speedtek issues, bin it and go cdoo# or 8hp. So many issues with these gearsets, a mate went through 3 rebuilds and multiple parts with heat, bearing and vibration issues.
    • I wouldn't go near them, they are rubber seals for a reason. Just chuck new cam cover seals, half moons and the spacers for the screws every decade or two. I add a really thin layer of silicone too and it seems to hold together OK
