Hi everyone,
Had this GTR for 2 years as a restoration project. Finally got it complete but think old age has gotten to me and am looking for my next challenge.
Interested in buying a euro or continuing down the path of a JDM car but probably something more daily (Accord, etc)...
So I'd be happy to do trades/swaps but it MUST be for a car within the 8 years... preferably with either cash my way but we can talk.
If not, the price is 25k
So the car...
All modifications done within last 2 years
Performance:
Rebuilt R33 RB26DETT (OEM specs) – Receipt will be provided (Completed Mid 2011)
New thermostat (OEM)
HKS Cam gears
ARC induction airbox
2 x Greddy T517Z turbos
HKS Type R intercooler with Greddy hardpipe
Split dumps
Mine’s equal length front pipe
Fujitsubo Legalis 304 cat back
HKS EVC 6 boost controller
HKS Turbo Timer – Type 01
Power FC and hand controller
HKS 600cc injectors
Nismo Fuel pressure regulator
Cusco catch can
C’s Short Shifter
Nismo Braided Clutch line
New OS Giken Triple plate and Flywheel (1/12/2012)
Nismo Clutch Slave (24/11/2012)
New Master Clutch Cylinder (1/12/2012)
Handling:
Greddy Type S coilovers
New bushes all around
HICAS Lock bar
Rebuilt driveshaft bearings (front and rear)
Cusco Front Strut bar
New rear diff
Endless CCX front and rear pads
SSR Type C – 17x9 wrapped in brand new Kumho KU31’s (25/08/2012)
4WD Wheel Alignment (7/09/2012)
BBS light weight wheel nuts
Cosmetic:
Full respray (Everything including engine bay) in R35 GTR - Ultimate Opal White – Receipt will be provided (Completed 25/08/2012)
N1 front bar with genuine N1 ducts and intercooler air guide
Genuine Carbon Fibre Exhaust Shield
R34 GTR valley cover
PIAA Carbon Racing wipers (Brand new – 27/08/2012)
Genuine R35 ‘GTR’ badge
Immaculate interior with brand new dash and OEM steering wheel (no bubbles)
Brand new leather shift boot and handbrake boot (black with red stitching)
Retrimmed genuine Recaro SR3 with Recaro low rails
Tomei 320km Speedo Cluster
Nismo GT500 shift knob
Full set of brand new Nismo Carpets
Kenwood 2 Din touch screen with Nav and Bluetooth installed (15/12/2012)
Alpine Type R series 2 speakers (24/11/2012)
Nismo Radiator cap
HKS engine oil cap
HID headlight kit
VIPER alarm system
All fluids flushed and replaced 2 years ago.
Serviced recently with Motul 8100 and Motul Inugel coolant (Last service 25/08/2012)
Recently had Redline Fuel System Cleaner (29/08/2012)
Redline Lightweight Shockproof Gearbox fluid
I've only got one word "Amazing" This has to be the cleanest modified 32 gtr on the market! That paint job................. :yes:
I say it's way to cheap.
Good luck
Dave
Thanks Dave, I really went all out no bars held.
The paint job was a full respray (So everything including the engine was taken out for the respray).
Hopefully the new owner will take care of it as well as I have thus far... only Zymol wax on that job
Edited by R34_Wong
  • 1 month later...
  • 3 weeks later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
