Hi all
Wondering if any of the Brissy / Gold Coast boys can suggest a decent steel supplier. I've found pretty big discrepanies in pricing over the years, so definitely worth shopping around. My usual supplier (South East Steel at Molendinar) has shut up shop, which is a shame because he was regularly 20-30% cheaper than anywhere else (maybe that's why they went bust?)
I'm doing the ring around and getting quotes from several suppliers (those who are prepared to answer phones, anyway) but was wondering if anyone knows of a good supplier I could talk to, maybe speed up the process.
I won't be buying in commercial quantities, so no point looking at a wholesaler who expects to sell 20 tonnes of steel a year before giving any discounts.
cheers.
https://www.sau.com.au/forums/topic/415806-steel-merchants-in-se-qld/
Don't all answer at once :P
I've sent off 6 RFQ's (2 of the 8 suppliers I tried to contact have had their phone number cancelled, so I can only imagine they've moved on).
Have received 4 quotes so far, and there's definiltley variation in the pricing. The biggest variation was for 5mm plate where the dearest was 124% dearer (yes, more than double the price) than the cheapest. The other stuff (RHS, angle, flat) saw a variation of 16% to 53% between the cheapest and dearest.
So far there doesn't seem to be any one supplier that's cheapest in every area. Some are cheap on one product, and dear on another. They will all deliver for around $50, too (looking at about a tonne of steel).
Definitely an interesting exercise. Shows that depending on what you're after, it's worth shopping around.
I guess you would call it industrial, although it's at the small end of the scale (up to 25x50 RHS, flat, angle, SHS). Do you mean plain mild steel tubing, or more exotic stuff (CrMo, CDS etc)? I had a bit of a search for your thread on tubing but couldn't find it. Care to post a link?
yeah i ment exhaust and cooler tube suppliers only, doesn't mean we cant have a big thread for industrial, cage and also thin tube suppliers as it should help out others
Edited by Dan_J
For cage material at the moment
Race tech are far cheaper for bare minimum CDW tubing than anyone else.
For 4130, performance metals have the best German milled material I've welded for a while.
I found to buy everyday material like RHS etc it was way cheaper to buy constantly from a local light fabrication shop that was buying tonnes per week. Despite paying his slight mark up it is still cheaper than buying direct from wholesalers when your quantity is comparatively low.
I was going to get it all in raw lengths (looks like about 45 full lengths in assorted sizes atm). Will need to get the plate cut though. I'm ordering 3 sheets of 5mm plate (2400x1200) and need to cut them into 800mm x 1200mm lengths. Was considering water cutting, as that gives a nice clean cut. I have a plasma cutter which should give fairly good cuts. Failing that I can always resort to the good ol' 1mm cutting discs on the grinder.
All the RHS, angle, flat etc I'll just chop to length with my drop saw. It will be getting a good workout int he new year.
Out of interest, how much do you charge for laser cutting? As I said, cutting 3 full sheets into 3 pieces each (6 cuts in total)
I work in the Engineering/Operating side so I can't give you a quote.
But I can probably organise one for you with the sales guys.
If you're talking about getting 3 sheets essentially cut down the middle I think the Lasercutting component would be very small.
Obviously they would also be able to organise material for you if you needed.
5mm steel cuts beautifully if the material is good quality.
With tube we can cut anything up to and around 12 meters in length, true 3d beveling etc.
we cut alot of roll cage stuff already.
Let me know if you want to know anymore warps.
Thanks for the offer, but Risking's suggestion makes perfect sense. Hadn't even thought of a guillotine before. Will give that a try first. It'll make the sheets easier to manage at my end too (didn't fancy trying to manoeuvre 113kg sheets of steel without plate clamps or a decent crane / forklift)
Most of the stuff I'm making won't need anything fancier than right angle cuts, so no need for fancy bevels. Will keep it in mind for future projects though (already have a few more projects on thr drawing board)
The first project will be a steel rack so I can store and sort all this steel I'm buying.
No problems mate,
straight cuts are really a waste of what the machine can do to be honest, it's amazing the profiles the tube laser can cut.
On another note, if you're looking for steel, have you tried this place ?
http://www.youtube.com/watch?v=icIwKaci3MI
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
