Hey guys,
I've just recently got into getting myself an r32 from having a few sr20s
My rb20det, standard except a exhaust. Has a weird issue on cold start that I cannot work out.
In mornings, the car will crank over, idle and become to warm up. But when I start to drive the car from 0-2000rpm it feels like it's hitting a wall until passed 2k then will drive perfectly fine. Now the weird part is if I even drive 3 houses down. Turn the car off and back on. Even though its still cold. It won't hesitate at all and drove perfectly fine.
I've done fault code tests to only come up with 55, I've cleaned the afm. Changed plugs, cleaned out coilpacs, I haven't yet had a chance to fiddle with the AAC unit just yet.
I figured it might be an ecu issue and by turning on and off the car it was resetting the cold start. But I have since swapped out the ecu for a working one off a friend with no change.
Anyone had this issue or can anyone enlighten me on it being something to do with AAC valve?
Thanks!
https://www.sau.com.au/forums/topic/415812-r32-skyline-cold-start-weird-issue/
Car runs rich until water temps hit 65degrees. This hesitation disappears when the water temp setpoint is met.
I have heard stories similar to yours in that you can turn off/on to over-ride the cold start fuel map but when I gave it a shot it made no difference for me...
Not sure if that helps.
I bought the car with water pump replaced. It takes forever to warm up. I may try driving it from cold and install my after market gauge and see if that is correct.
Cheers for the reply
sounds like thermostat is stuffed if car takes forever to warm up. Means the car would always be running rich. Check that out.
I just drove it today. As I hardly drove it. Hasn't been started in couple days, it's a nice warm 27 degree day. Stated and idled perfect, drove it, does the rubber band effect till I turn the car off an then back on. Then it drives fine?
I also let the car warm up while it was doing the hesitation and it didn't change. Only until I turned it off and then back on straight away.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
