Yo, I've got a maroon series 1.5 R33 Skyline for wrecking here in Sydney. It's got a stuffed/blown auto gearbox, slightly dented roof and no rego so i'm just wrecking it !
If you're after anything listed here or any other random parts, reply or flick me a PM
post-35556-0-95342700-1355748072_thumb.jpgpost-35556-0-38843500-1355748083_thumb.jpgpost-35556-0-47407300-1355748244_thumb.jpg
Pickup in Sydney, or I can post pretty much everything anywhere in Australia. It's got some aftermarket parts, listed here first:
Aftermarket parts:
Kinugawa T67-T25G high mount turbo kit. Includes everything you'll need - Turbo, XSpower highmount manifold & 44mm wastegate (plumbs into split dump), 3" stainless split dump pipe, oil feed lines, hoses/clamps etc. Turbo is in immaculate condition, less than 2000km old. XSpower manifold is HPC coated black, also less than 2000km old - $1700 ONO
There's a massive thread with loads of info on these turbos here: http://www.skylinesa...dynamics-turbo/
post-35556-0-28419300-1355745834_thumb.jpg post-35556-0-63041800-1355746002_thumb.jpg post-35556-0-03117500-1355747125_thumb.jpg
HKS Hiper D height and damper adjustable coilovers, front and rear. Great condition - $700 ono
Carbon fiber bonnet, suit series 2 R33 (with s2 grille) Some small cracks / patches in the clear/coating. Includes bonnet pins - $400 ono, pickup only !
Apexi Power FC ECU to suit R33 Gts-t rb25det, good working condition - $800 firm
3" high flow catco cat, flanged to bolt right up to r32, r33 Skylines, S13s etc - $100
Also have a set of brand new / unused Nismo 555cc injectors. Still in boxes, with the nismo paperwork etc - $600 (these are still $900+ fron nengun, without shipping)
X-Racing FMIC & piping kit, suits R33 Gts-t. Good condition, includes all pipes and hose clamps - $250 - pickup only
SF-DIS-005 Splitfire coil packs, suits S1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Z32 AFM and matching plug, good working condition - $180
Oil Catch can - $40
XTR turbo beanie, the mesh on the underside is a little worn in one area. Will still work great though - $60
Set of 4x 17" R34 GT-T wheels and tyres. Wheels are in good condition, only a few tiny areas of gutter rash
Tyres still have pretty good tread- all 4 are at approx 50%. Unfortunately one of the tyres has a screw stuck in it and was (very) slowly losing air - $400. Can post if required !
PWR auto transmission cooler & hoses - $75
Blitz pod filter & adaptor, etc - $25
Also have a fiberglass R33 GTR front bar (with lower lip), no indicators/lights, painted Silver. Great condition - $400 ono Pickup only
Walbro fuel pump in R33 Gts-t cradle - $100 ono
(no pics yet)
The engine has approx 187,000k's on the clock and was running great. Rocker covers painted maroon
I did a compression test last week and it was great - bang on 150psi on all cylinders - $900 ono for the bare engine
Auto gearbox is still here but 3rd and 4th are blown (on the dyno) good for parts maybe? - $50
Exterior Stuff:
Series 1 headlights - sold pending payment
Series 1 reo bar, cut for FMIC - $150
Series 1 front bar (small section of the back of the lights was cut for FMIC, doesn't effect operation - $250 - pickup only
Front guards - $75 each
Bare nose cut/radiator support - $150
S1 grille - $60
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts - $150
Engine bay stuff:
Aircon condenser - $125
R33 aircon compressor pump - $90
R33 power steering pump - $100
R33 alternator - $90
S2 (no ignitor) Rb25det engine loom - $150
Engine Mounts - $75/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Brakes/driveline:
Front calipers - SOLD
Rear calipers - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front castor rods - $75/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $140 pair
Handbrake drum assembly incl cables - $150 pair
Rear differential (4.3) auto diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Also have a full set of standard suspension - $150
Interior:
Complete set of floor mats, good condition - $80
S1 Front seats, good condition, small bit of wear/hole on the driver's side in the usual area - $120 - pickup only
Complete set of S1 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Driver side window switch (12 pins)- $75
Instrument cluster, approx 187,000km. tacho not working properly (jumping around) - $50
Painted dash surround & auto gear stick surround - $120. Includes boost gauge mounted in the cluster surround
Centre console, with good lid/latch - $50
Seatbelts (full set) - $100
Ignition barrel + door barrels & key - $90
  • Replies 40
Where abouts in Sydney? S1 grille still for sale and no clips broken?
St george area. Still for sale, 2 of the 5 clips are missing, still clips up fine to the car
Can you pm me your contact number please
PM sent
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
