Yo, I've got a maroon series 1.5 R33 Skyline for wrecking here in Sydney. It's got a stuffed/blown auto gearbox, slightly dented roof and no rego so i'm just wrecking it !
If you're after anything listed here or any other random parts, reply or flick me a PM
post-35556-0-95342700-1355748072_thumb.jpgpost-35556-0-38843500-1355748083_thumb.jpgpost-35556-0-47407300-1355748244_thumb.jpg
Pickup in Sydney, or I can post pretty much everything anywhere in Australia. It's got some aftermarket parts, listed here first:
Aftermarket parts:
Kinugawa T67-T25G high mount turbo kit. Includes everything you'll need - Turbo, XSpower highmount manifold & 44mm wastegate (plumbs into split dump), 3" stainless split dump pipe, oil feed lines, hoses/clamps etc. Turbo is in immaculate condition, less than 2000km old. XSpower manifold is HPC coated black, also less than 2000km old - $1700 ONO
There's a massive thread with loads of info on these turbos here: http://www.skylinesa...dynamics-turbo/
post-35556-0-28419300-1355745834_thumb.jpg post-35556-0-63041800-1355746002_thumb.jpg post-35556-0-03117500-1355747125_thumb.jpg
HKS Hiper D height and damper adjustable coilovers, front and rear. Great condition - $700 ono
Carbon fiber bonnet, suit series 2 R33 (with s2 grille) Some small cracks / patches in the clear/coating. Includes bonnet pins - $400 ono, pickup only !
Apexi Power FC ECU to suit R33 Gts-t rb25det, good working condition - $800 firm
3" high flow catco cat, flanged to bolt right up to r32, r33 Skylines, S13s etc - $100
Also have a set of brand new / unused Nismo 555cc injectors. Still in boxes, with the nismo paperwork etc - $600 (these are still $900+ fron nengun, without shipping)
X-Racing FMIC & piping kit, suits R33 Gts-t. Good condition, includes all pipes and hose clamps - $250 - pickup only
SF-DIS-005 Splitfire coil packs, suits S1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Z32 AFM and matching plug, good working condition - $180
Oil Catch can - $40
XTR turbo beanie, the mesh on the underside is a little worn in one area. Will still work great though - $60
Set of 4x 17" R34 GT-T wheels and tyres. Wheels are in good condition, only a few tiny areas of gutter rash
Tyres still have pretty good tread- all 4 are at approx 50%. Unfortunately one of the tyres has a screw stuck in it and was (very) slowly losing air - $400. Can post if required !
PWR auto transmission cooler & hoses - $75
Blitz pod filter & adaptor, etc - $25
Also have a fiberglass R33 GTR front bar (with lower lip), no indicators/lights, painted Silver. Great condition - $400 ono Pickup only
Walbro fuel pump in R33 Gts-t cradle - $100 ono
(no pics yet)
The engine has approx 187,000k's on the clock and was running great. Rocker covers painted maroon
I did a compression test last week and it was great - bang on 150psi on all cylinders - $900 ono for the bare engine
Auto gearbox is still here but 3rd and 4th are blown (on the dyno) good for parts maybe? - $50
Exterior Stuff:
Series 1 headlights - sold pending payment
Series 1 reo bar, cut for FMIC - $150
Series 1 front bar (small section of the back of the lights was cut for FMIC, doesn't effect operation - $250 - pickup only
Front guards - $75 each
Bare nose cut/radiator support - $150
S1 grille - $60
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts - $150
Engine bay stuff:
Aircon condenser - $125
R33 aircon compressor pump - $90
R33 power steering pump - $100
R33 alternator - $90
S2 (no ignitor) Rb25det engine loom - $150
Engine Mounts - $75/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Brakes/driveline:
Front calipers - SOLD
Rear calipers - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front castor rods - $75/pair
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $140 pair
Handbrake drum assembly incl cables - $150 pair
Rear differential (4.3) auto diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Also have a full set of standard suspension - $150
Interior:
Complete set of floor mats, good condition - $80
S1 Front seats, good condition, small bit of wear/hole on the driver's side in the usual area - $120 - pickup only
Complete set of S1 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Driver side window switch (12 pins)- $75
Instrument cluster, approx 187,000km. tacho not working properly (jumping around) - $50
Painted dash surround & auto gear stick surround - $120. Includes boost gauge mounted in the cluster surround
Centre console, with good lid/latch - $50
Seatbelts (full set) - $100
Ignition barrel + door barrels & key - $90
  • Replies 40
Where abouts in Sydney? S1 grille still for sale and no clips broken?
St george area. Still for sale, 2 of the 5 clips are missing, still clips up fine to the car
Can you pm me your contact number please
PM sent
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
