Hi all!
need some major help with my skyline, renctly wound the boost up to 1.3 bar for a track day,
long story short blew exuast manifold gasket, put a new one in took it for a drive and the car hesitates to boost, at about .3 bar it feels like it hits a wall. looses all power until you take foot off the throttle and it will come back to life.
Ive changed;
Spark plugs and gaped to .8
new coil packs
AFM
checked;
sensors
boost leaks- none that i could find with carby cleaner
Also tried re setting the ECU
Can any body throw some suggestions my way??
https://www.sau.com.au/forums/topic/415844-rb25det-fuel-cut/
well the guy that advice me to do that organises all the drift meets here, forgot to mentioned i thort i might have blown the turbo so i took it out and checked it but it seems to be fine and ive also put another standard turbo on just to eliminate that possability,
ive wound it back down to standard psi, now its running rich on idle and when it starts boosting feel like you hit a wall
ive searched RnR but not convinced that its that..
anither thing is when it starts boosting (before it hits the wall) it soulds like the psi coming out some where from the left hand side, sounds odd and its hard to explaind but ive looked at thres for the last couple of months tryi to diagnose this problem
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
