it revs past 2500 rpm.. but good chance the replacment was a dud to.
so frustrating
nah mate if it goes past its working... could have dry joints on the solder inside causing it to cut the signal when you hit a bump.
i just spoke to the old owner and he said the car has a fuel cut defender making the car capable (not safe) of 13.5psi which is what it had goin threw it and it ran fine!
i am thinkin a might have nudged a wire or something when i was changin the exuast gasket... sound like a likely possabilty??
hmmmmm...
first of all. locate that FCD take it out, rewire the loom back to standard. then kill the fcd with fire.
wind your boost down to under 10 psi after that and see what its like.
give the engine a f**king huge service. fuel filter air filter oil filter upper engine cleaner etc, check your tps voltage clean your iac valve then reset your ecu again.
that should take you about a day working easy with beers. even if none of that is the issue, when you find the issue your engine will run shit loads better.
okay so its definatly not the fuel cut defender! put the emanage ecu back in and it idles okay but now it sounds like a WRX and still sounds like the air is leaking some where from the left hand side...
soapy water on hoses should sho up leaks.... not to much tho and watch electrical....
do you not have a stock ecu to put in?
if it sounds like a wrk its missfiring... check coil packs and harness.
i never said the FCD was causing your problems but it willllll. throw it or sell it. you wont need one after you have the emanage tuned.
haha f**k this man, so now its missfiring and not boosting properly...
ive checked and checked for leaks i was thinking maybe theres a crack in the intercooler??
The ecu is stock witha piggy back e-manage.
it seems to be holding idle now and doesnt want to stall when you come to a stop.
would it be throwing out error codes??
all the issues i had with mine it never threw a code......
unplug your piggy back, run on standard ecu, reset it. dial boost to just under 10. put 98 octane fuel in. see how it runs. get it right on stock parts then add one upgrade at a time to see what is causing the issue. if you put it back to stock and its still doing it, then you know its not those parts and you can figure out what its doing.
also if that emanage has a tune loaded on it and you dont have the right mods etc you could do some serious damage!
its been tuned with the emanage capable of 13.5 psi, But yeah this will be the third time ive strated from scracth
i guess that what ya get when ya buy someone els car ( no knowing exactly what hasn been done or any problems its had)
I said to this missus last night i was ganna sell it and get a 4 banga haha :verymad:
Was about to say check the pipe between the AFM and turbo inlet - also check the plumbing of the BOV return pipe that joins before the turbo.
BTW - don't take advice from random people about turbo cars. SAU is the best source of info for for RB engines.
  • 1 month later...
My only question after reading this is....
Why the hell would you run 18psi when you've got an emanage which is tuned for 13.5psi... That's just asking your engine to lean out and destroy itself! Especially for a track day when you're going to be Wide Open Throttle all the time...
Yeah, normally people turn the boost DOWN for a track day. You don't need the power on the track, it's better to have moderate power and concentrate on being smooth and taking good lines. An extra 20-30hp at the wheels isn't going to make a huge difference if you are a nooby.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
