Hey guys,
I am a bit of a newbie to SAU forums, I used to be on hardtuned.net alot but the 17 year olds with bad attitudes got a bit much.
I have a track car thats not complied for australian roads, I keep reading just about every week about a skyline, stagea, etc getting stolen and its making me paranoid. I live in Adelaide and the car is usually stored at home, I have a cheap wheel clamp on one of the front wheels but its pretty basic.
Being a track car I really dont want to fit an alarm as such, I really dont need the headache if the thing plays up as it would be really a pain to get the car back to wherever it gets fitted for warranty work.
I cant imagine I am the only guy out there with the same situation, what are people using to protect their pride and joy ?
I know there are other topics about this, but it seems the flaming of people takes precedence over helpful information.
So please refrain from turning this into the same, I really dont need the bother.
Edited by Ricky_Bobby
https://www.sau.com.au/forums/topic/415918-how-do-you-protect-your-track-car/
A basic tracker can cost up to $800 depending on its features and the features you want wired up, the installation (whether you pay a pro or do it yourself) and of course the brand of product. A basic tracker will also need a simcard to send you location info whenever you ask it, and the costs associated with txt messaging which is very minimal if you use the same phone carrier as your personal phone. It would not cost more than $10 per month if you had it on a basic plan (Telstra). Some carriers offer a 365 day prepaid plan which needs topping up annually, with that kind of plan it would probably cost around $20 for the whole year. There are no other annual monitoring costs or subscription costs associated with these trackers because you are doing the monitoring personally. They are a one time purchase product so you can remove it and put it into your next pride and joy.
You can be lying on a beach on Hamilton Island and know exactly where your car is within seconds.
You can get mini GPS trackers on Ebay for $50.
Just get a prepaid sim card with 365 days expiry for $30
That's it.
They are rechargeable or you can wire them to your battery.
Comes with PC software for tracking.
So you can pole (call) it anytime and the location is sent to your phone or PC.
I think each time is the same charge as an sms.
Gotta be the cheapest way for tracking.
If you're mainly worried about drive off theft, and only drive a couple times a year, disconnect your battery and pull some key fuses out.
That's it.
A mini tracker is fine for tracking a girlfriend lol or your skate board
But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips
and be able to be hidden in a stripped car as well
yes it can be done
expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car
The catalog points out the flaws that failure to communicate starts around 30c
( iPhones do that too )
It has no external antennas so range is average if it can't see the sky clearly
Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc
Telstra towers are the best option in most cases and services that use those
so as you can see going cheap might cost you a car !!
A mini tracker is fine for tracking a girlfriend lol or your skate board But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips and be able to be hidden in a stripped car as well yes it can be done expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car The catalog points out the flaws that failure to communicate starts around 30c ( iPhones do that too ) It has no external antennas so range is average if it can't see the sky clearly Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc Telstra towers are the best option in most cases and services that use those so as you can see going cheap might cost you a car !!
Thats a fair point, I wonder if there are ruggedized (yes its a word !) versions or maybe I can make my own.
Being in South Australia, you could almost say 80% of the year the inside of the car will be 30degrees or hotter. So that probably rules the cheaper option out , surely somebody (a manufacturer) has identified a spot in the market to make something that can withstand these sorts of issues but without the $800 price tag. Seems excessive for a pretty common technology these days ?
Plenty in the 200-250 range without install
external antennas ( tiny ones)
And alloy case with heat sink ( tiny too)
at least 10 companies make them not including eblow ones
They offer full features and can trigger a remote item like alarm or kill switch
They send out GPS coordinates in SMS and clicked onto it google earth or maps opens
Highly accurate tested to within 1 meter of real location in a poor coverage area with lots of metal and houses around it
a rubber mat and soft rubber mounting used on screws fixes up a fair bit of vibration
It also stops heat transfer from the actual car body a bit without breaking the ground plane
Most of the heat is from car, motor or sun , the unit is only room temp otherwise even charging up
I never referred to a mini tracker in my earlier post and if they cost $50 then why shouldn't they play up and fail in 6 months. You cannot expect quality for that price even for a kids toy these days. If you cannot afford a $300 to $400 vehicle tracker and you have a track car that you have spent thousands of dollars on then just strap your car down with $50 worth of chains and padlocks people!
People spend thousands of bucks on car audio, engine and interior, but do not want to spend a few hundred dollars for its security???
The better products that I am referring to will not fail, due to heat and vibration and I have never seen one fail as a result of this. Been fitting them for years to everything including track cars and excavators. They also have separate antennas for both GSM (to communicate to the owner) and GPS to collect data from the satellites.
I do not have any links where you can purchase these trackers but Google will give you plenty of results. I am here to advise on security options, not to do the shopping around for people.
The $800 price tag I mentioned was a general price (as I cannot give accurate prices for everyone that sells them) and would be the highest price you would probably pay which would include installation. This is still quite cheap compared to a monitored tracking system and service which can cost up to $2000 for the tracker and installation plus $200 - $300 per year for monitoring costs. If you want accurate prices then do some searching, make some phone calls, compare their prices and their features.
If your budget is only $50 then your cheapest option is to sleep in your car or sell it to pay the bills.
Yeah what Daniel said lol
+1
contact quiktrack i had one of their systems in my s15... much better then any of the ebay ones but theres montly fees ect, but other advantages as where car can be turned off via satellite systems.
http://www.quiktrak.com.au/
My advice, don't contact Quiktrak, as they are way too expensive! Arn't we talking about keeping the costs down?
Most basic trackers that I refer to can still shut the car down by you, by a simple sms text message whenever you want to. Also can unlock doors by sms if you lock you keys in the car by accident.
Exactly what I was going to say mate lol
Any decent tracker can do remote shut downs and much more and cheaper then quicktrak or DEI viper setups
But these "how to's" won't be advised to the DYI ever , if you don't follow that warning you could kill someone !!
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
