I took my R32 GTR down to the drags tonight for the first time, and while I ran an 11.7 which I'm reasonably happy with I'm a bit concerned about the MPH. I have read quite a number of threads on here and given what others have run with similar setups I thought I would be quicker.
My previous R32 made 410rwhp (roller dyno) and this one made 470rwhp on a hub dyno. Now sure, dynos are dynos and the true measure is MPH at the strip. However, my last 32 did 11.8 @ 118mph on that horsepower, and my current 32 went almost dead on the same at 117.5mph. I had 4 runs all up, 11.7 then missed gears on the next 2 and then the fourth run I did a 12.0 @ 116mph.
I read through threads such as Marko's and with 325rwkw he was getting low 11s so I thought I would at least get 120-122mph. I have also studied the how to launch your GTR threads, the quarter mile in your 34 GTR thread etc etc. http://www.skylinesa...-gtr-the-creek/
Being that it was my first time at the drags with this car I didn't think I was going to get a great ET but should I have been expecting a higher mile per hour, or is it about on the money?
Here are the results from my first and last runs:
First
60' - 1.780
330' - 4.968
660' - 7.613 (speed was 151.73kph)
1000' - 9.863
ET - 11.776
MPH - 117.49 (189.08kph)
Fourth
60' - 1.757
330' - 5.052
660' - 7.771 (speed was 147.84kph)
1000' - 10.112
ET - 12.062
MPH - 116.73 (187.85kph)
The car's running a GT3582 @ c.19-20psi, has cams but not sure of specs, twin plate clutch. Tyres are Falken Ziex ZE912s (245s). Launch method was supposed to have been slip the clutch out at about 7000rpm but it turned into more of a sidestep at 7000rpm, and I tried to change gears as quickly as I could at about 7500rpm.
Any insight, particularly with reference to the above times at various points down the track, is muchly appreciated so I can practice a little more knowledgeably next time :)
https://www.sau.com.au/forums/topic/415939-r32-gtr-is-my-mph-low/
In a heavier than stock R33 GTR (larger sump, radiator, brakes, coolers, 18" wheels etc) - I was running 11.4 @ 124mph with 335-340rwkw.
You are in a much lighter car with a tad less power (410rwhp = 305rwkw), so you should be pretty much the same to be honest. I'd say your setup has issues.
Your 60fts are good (so it's not a clutch problem) and your MPH isn't necessarily "too" low, but you would expect to be 120-122MPH at the least and that means you are probably not even making 305rwkw to be honest. A friend of mine years ago ran 117-118mph on stock turbos in a R32 GTR :)
Also the fact you have a GT35 @ 20psi and only 305rwkw, is also telling something. A GT35 on that much boost you'd be expecting closer to 350-370rwkw on a stock motor. So combined with the MPH, it's telling you there is something pretty wrong to be a good 8-10MPH down on what that turbo/setup is capable of.
Hi guys, many thanks for the responses. Mico, I'm not sure to be honest mate, the cams were installed by the previous owner. As R31Nismoid indicated the MPH seems reasonable for a low 300 kilowatts but given it last dyno'd at 470rwhp (hub) I agree, there must be something at fault with the setup.
Thanks guys, I will look into it :) As least there's potentially a few more MPH in it without changing too much!
Often you'll find hub results are not the same as a chassis dyno. They tend to read higher, so I'd still say you've got less than 300rwkw (which 117mph would suggest).
So easily down 50-70rwkw, which you'll notice once you get it - it'll be a different car and you will easily pick up 8MPH. Possibly a bit more.
To give you some perspective. A GT3076 (500-550hp turbo) will make around 300rwkw on 20-22psi. You have a 700hp turbo, that on 20psi has made 350/370rwkw on many many cars. A quick check of the dyno results thread would show you how easy and how many have done it :
Cheers mate, I keep a regular eye on that thread which is why I thought something was amiss given my 118ish mph. The ~330rwkw mark was always my 'target' I suppose so I'll get it back on the dyno in the new year and see if we can't figure out what's happening.
Cheers again for the feedback, appreciate it :)
  • 4 months later...
i ran 11.8 on 234kw on 98 octane stock turbos just replaced with steel wheels
stock ecu , ku31s all round. ( excuse my screaming after the race... was tad excited )
time slip is in description.
got abit of a list of parts to buy.... keen to see my future result. Edited by sultanaz
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
