Getting this weird rattling noise every time i go on a bump, even the smallest bump or a slight dip in the road causes this irritating rattle. The best way i can describe the sound is like a piece of hollow plastic pipe tapping against metal. I already tried emptying the boot (removing jack, spare tire, rear seats, tied up all cables etc) and trying to identify the source of the noise. It sounds like its the suspension but i dont know what part of the suspension it could be. Is it the bushings? Or has something just come loose like the shocks? Its going to be a pain in the ass if i have to remove the damn parcel shaft to get to the rear shocks ==' All i want right now is to know where the noise is coming from, driving me nuts.
I also tried pushing some weight on and off the car while its stationary to see if the noise appeared but i couldnt hear anything, its only while driving. Already checked the passenger side drive shaft. Also i had the k-frame replaced 5 months ago, but the noise existed prior to the replacement of the kframe.
Cheers in advance for the responses =)
Already took out the seats and checked bolts on the parcel shelf, Its more of a mechanical sound so ive narrowed it down to a component in the suspension itself. Ill check the bushes now, but theres like 50 bushes ==' Could be anything. How much would it cost to change the bushes? My front sway bar and shock absorber bushes are worn out too. Do i need to change all the bushes?? or just the ones that are worn out?
Could it be a worn out bearing? What sort of suspension are you currently running?
My whole suspension setup is stock, stock shocks, stock springs, everything stock. Car's only run 79,000ks. Was planning on lowering it on low king (or tein) springs 30mm drop.
Do you mean the wheel bearings or is there another bearing i dont know about?? cause i just had that checked while i got new brakes done.
Edited by Deza3000
Just came from a drive, the noise sounds like when you bounce a basketball 5 cm off the ground very fast. The rattle persists for 1-2 seconds on every bump.I ran over a small stick and it rattled like a bitch.
could also be the bolt that hold your parcel shelf support bracket on.
whip seats out and take a look. takes ten mins.
thats what im suspecting aswell a lose bolt in the cabin coz i have new coilovers
You reckon i should just remove the whole parcel shelf, brackets and everything to identify the rattle?
I found my problem it was the lose scissor jack screw.So happy.now got a bit paranoid that the coilovers.were.faulty
Oh really?? where abouts is the screw located? ill try and have a look.
Ha. I had that happen years ago. Annoying rattle went on for a couple of weeks before I found it.
He means the jack is held into its receptacle in the left rear gaurd by its own screw tension. You slide it in and wind it "up" until it holds itself in place. If you leave it in there loose it rattles.
Edited by GTSBoy
I took out the whole jack and theres stll the same rattle, it has reduced a little, i also tightened all the nuts the jack holds onto. Im beginning to think its coming from the parcel shelf, ill probably take that apart next to identify the problem.
Finally found the cause of the rattle, turns out its the heat shield in-between the boot and the muffler, Might wedge an aluminum piece in there to stop the rattle.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
