Up for sale is all my Pentax gear, everything is in as new condition all lenses apart from the 50mm manual focus have protective lens filters fitted from new.
Pentax K7 DSLR body
Sigma Lens 70-200 f2.8 http://www.digitalcamerawarehouse.com.au/prod6758.htm
Pentax Lens 16-45mm f/4 ED AL DA http://www.digitalcamerawarehouse.com.au/prod1341.htm
Pentax DA 40mm f/2.8 XS Pancake http://www.bhphotovideo.com/c/product/842479-REG/Pentax_DA_40mm_f_2_8_XS.html
Pentax 50mm F1.8 manual focus auto aperture
Pentax AF 360 FGZ Speedlite http://www.pentaximaging.com/accessories/AF360FGZ
3 piece extension tube set
Tripod in bag (new)
The lot for $2200
Pickup from Sydney or I can courier at your cost.
I might seperate if anyone is interested in specific things let me know.
https://www.sau.com.au/forums/topic/415950-pentax-k7-dslr-package/
  • 3 weeks later...
Everything in as new condition plus boxes, instructions, cables ect for the camera body, flash and most lenses. Alot of $$ spent on all this gear.
Price drop to $2,000 for the lot!
  • 3 weeks later...
Price drop $1800 for the lot. OR
Pentax K7 DSLR body $550
Sigma Lens 70-200 f2.8 $550 (Includes Hoya Filter)
Pentax Lens 16-45mm f/4 ED AL DA $200 (includes Hoya pro1 digital filter)
Pentax DA 40mm f/2.8 XS Pancake $200
Pentax 50mm F1.8 manual focus auto aperture $100
Pentax AF 360 FGZ Speedlite $200 (with diffuser)
  • 1 month later...
speedlight sold, following still available:
Pentax K7 DSLR body $500
Tamron Lens 70-200mm SP AF f/2.8 Di LD (IF) Macro $550
Pentax Lens 16-45mm f/4 ED AL DA $200 http://www.digitalca...au/prod1341.htm
Pentax DA 40mm f/2.8 XS Pancake $200 http://www.bhphotovi...m_f_2_8_XS.html
Tripod in bag (new)
The lot for $1500
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
