The D1R spokes recess back into rim a fair way towards the end, this is what will give me a problem if anything as Brembo rotors are bigger than standard which will push the calipers out towards these
Think i'm going to have to find a GTR with Brembo's and do a trial fit just to be sure
Had r33gtr brembos at the front with d1r 18x9j +15.
Though it's on a 200sx s14, it should clear on a r32/r34.
Recently changed to lmgt4 at the front 18x9.5j +12. clears front brembos heaps.
Edited by ravewar
Cheers mate. Only got the fronts done. The rears are still pretty standard.
All parts purchased here, courtesy from SAU!
Yeah, awesome!
R33 GTR Brembo Calipers?
What 2 piece rotors are they?
Yeah, awesome!
Hey mate,
Yeah, calipers are r33gtr brembos. Rotors are from http://x3emotorsports.com/cart/index.php?main_page=index&cPath=6_196
Been using it for a couple of months now in my daily. No issues at all.
Can't say much about track, as I haven't done any track work yet.
Hey mate,
Yeah, calipers are r33gtr brembos. Rotors are from http://x3emotorsport...dex&cPath=6_196
hey mate,
how much did you pay for the 2pc rotors?
Cheers
Rotors look like DBAs.
Hey mate,
Interesting... Good to see another local manufacture in the game.
Thanks for that.
Does anyone know if the Lenso D1R's in 18x10 with +20 offset will fit over a set of Brembo's?
Looking seriously at a set off an R34 at moment but don't want to buy another set of wheels as mine are brand new
Cheers
I recently bought dogbones and 324mm rotors on r32 sumitumo calipers. And the lenso 17x10+18 and the calipers are just touching the barrel of the rim so zero clearance so an inch bigger diameter wheel should give you plenty of clearance. Assuming the sumitumo is similar in size to the brembo.. The lenso d1r seems to be really crap for caliper clearance worse by far compared to all my other rims.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
