My apologies if this topic has been covered many times before, I have read through them and there's no real conclusive answer.
The time has finally come to make an upgrade. My mate who used to own an S15 loved it, said the handling was better than any skyline, it was zippy (light weight) didn't steer like a boat and had decent power. Whereas all I can see now, are paper figures the R34 GTT being ~120kg more heavier but having a LOT more modable power available. I asked my friend about this, and he said that 120kg separates the cars in two different worlds (HUGE DIFFERENCE). Having driven an R34 stock GTT and sat in a stock S15, I can tell that stock for stock, the S15 is lacking by far, whereas driving the GTT, the RPMs climb so fast it's insane.
That being said, the S15 didn't have much low end torque either, I can't even say that it had as much torque as my naturally aspirated R34 did.
I've asked many prestigious car owners who have owned multiple S15s, EVOs, and R34s over their time, and they keep telling me the S15 was the best out of all of them. I just don't see how good the S15 is.... I mean 120kg lighter but it has the SR20 which is a prestigious engine, but certainly not as invincible nor can it obtain easy power as the RB25DET can?
So I'd like you fellas on this forum to tell me 3 things:
1. Does 120kg on road make a HUGE noticable difference?
2. If so, does the easy power of the RB25 make up for this difference?
3. Ultimately, which car would be best for fun, torque, daily and track?
Cheers!
https://www.sau.com.au/forums/topic/415959-200sx-s15-or-r34-gtt/
drive a s15. don't just go off sitting in the passenger seat as it doesn't give you a true feel for the performance of the car.
as for the reason why all the other threads have been inconclusive is the exact same reason as why this one will be just as inconclusive. everyone has their own opinion. just drive the 2 and buy whichever you prefer. plain and simple. no point buying a car based off other peoples opinion if you don't agree with it.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
