This car is my pride and joy. I have meticiulsly maintained this car, oil changed every 5000km. Previous owner did ground up build, respray and inspected gearbox/turbos before reassembling.
Full inside and out respray, with seam welding done along the chassis. Resprayed in a Mazda 3 Colour Silver. Can supply numerous recipts from myself and previous owner. Am happy to put up on hoist for inspection etc.
Suspension:
D2 Coilovers 1yr/old
Adjustable Camber Arms Front and Rear
New wheel bearings
Urethane Bushes
New Ball Joints
Rebuilt CV
Supension Arms removed and Powder coated
Varostoen 19in Wheels in Matte Black (TE37 Lookalike)
Brakes:
DBA 2500 Rotors on front
Stainless Steel Braided Brake lines
QFM A1RM Pads front and Rear
Motul RBF 600 Race Fluid
Engine:
Healthy engine, Good Compression Stock Boost
New HKS Metal inlet gaskets
New heater hoses under inlet manifold
Spitfire Coilpacks
3.5in Exhaust
Relocated oil filter, with oil Cooler
Moroso 3quart Accusump mounted in boot
Earls Stainless Braided -10 lines on Oil Cooler and Accusump
Penrite HPR 5w-40 Synthetic
Oil systems takes roughly 7L
Interior:
Sony AUX Headunit
Momo Steering wheel
Jaycar 5" speakers in the rear
Fire Extinguisher Mounted in passenger footwell
Mongoose Alarm fitted at Carbon Car Systems
Looking for $24000 ONO.
Located in Parramatta
Call Aaron on 0412 508 903
post-93127-0-95717000-1355988555_thumb.jpgpost-93127-0-70306800-1355988509_thumb.jpgpost-93127-0-97154000-1355988471_thumb.jpgpost-93127-0-19325400-1355988468_thumb.jpg
https://www.sau.com.au/forums/topic/415960-1992-r32-gtr/
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
