I have bought a $30 adjustable boost controller off eBay.
Iv hooked that t peice that comes in the kit between the acutator and the intake vac hose.
With the middle nipple on the tee iv ran it to the boost controller.
The boost controller has just taken the solenoids spot.
Iv turned the boost controller to negative side and I'm still getting rediculas boost results.
Iv swapped a few hoses around and the boost is still amazingly high?
Any help will do thanks alex
https://www.sau.com.au/forums/topic/415964-boost-controller-issues/
If u can't figure out a simple thing like a f@&kin boost controller u shouldn't own a turbo car! Sell it and buy a holden
Maybe you should buy a holden since your mental capacity is on par with the stereotypical bogan driver.
Anyway, on topic, throw up some pics as this would help a lot.
Never ask you for help.
Didnt expect this from a volvo driver. Take a chill pill bro.
OP, pics are your friend here.
+1
The bloke is just asking for help u f**king dickwad.
+1
+1
more info would def help here however you generally have to wind them all the way shut (off) then adjust from there. Depending on the brand/type can be a slight turn of 4 turns to get a single PSI increase
Wow, with a comment like that you must have a really big cock, cause that's what you now look like f*ckface!
From what I'm reading, sounds like you've hooked it up wrong. The stock boost controller (assuming you have a GTS-t) actually bleeds back pressure between the pressure hose to the actuator.
What you need to do is remove that OEM t piece and fit your controller between that hose as per the diagram above. then block off the hose going into the intake.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
