2013 ACT Skylines Australia Calendar
January - Group shot from raised position ?
February -
March -
April - S T A R 3 3
May - Shell
June - Manuel Kasko
July - Not a Pulsar
August -
September - GTRKat
October -
November -
December - Anfanee :santa:
Date: Sunday 30th of December Suit most ?
Location: Mitchell workshop or Lake, Hill, Industrial ???
Start Time 10:00am ?
Photographer: Eiji? or ???
Printing: Jason FASTdigital or maybe Shell ?
Cost: $25? if possible
May need to put 2 or 3 cars together depending on numbers attending
  • Replies 367
Although my camera doesn't take a bad shot for an 11 year old 4mp Sony, as used in my sig,
A digi SLR would be preferable. I don't mind havin' a crack if need be though.
All sounds good to me so far.
Just remembered i dont have rego :(
Ill have to pass then lol
As per 'FYP' post, get a day permit :P $38.50 I think, which is a rip off but still you don't need any inspections or anything.
i am northside rego has been out for longer than 12 months :(
k can try get a trade plate tho, my boss has one somewhere
If you're prepared to put rego on your car, do it online on the RTA website. I'm not sure if it's been fixed yet, but the website allows a loophole of sorts that doesn't actually STOP you if it's been more than 12 months...it just says you're supposed to get an inspection done, but it will still let you renew it anyway LOL
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
