These photos look epic..... Love the cartoon effect,
No worries guys, thanks for the donations for the E&B rolls helps cover the cost for them.
Was good to meet you all as well and put a face to the names.
Speaking of which if anyone has any photos of the shop in the backround or even inside the shop flick them through pm or add them here so a can put a few up in the office..
Thanks guys
Edited by ScR33m3r
  • Replies 367
For all those who took photo's today.
Can you create a folder with your Name on it and I can come to you to pick up on a 32gig stick
or put it on a stick and I'll grab that.
Happy to distribute to others.
Remember this is a Calendar and more pics are being organised with indiviuduals. Be patient please.
Once we have the complete compilation the best will be chosen, with your input on Pics of your vehicles, and the final results provided for publication.
At least thats what I think. If you have better suggestion please share.
Who let the Volvo in ? Yes RB26 - No not a GTR
Hard to find fault with this one. But I have it on good authority he is actually from OS.
No leak under the car. But it looks like I need to go
Billy Elliot ? FTW
Absolutely glowing couple
Dont see this one out often enuff
4 doors! who are the other 3 for ?
Argh - Cap'n Jack Sparrow
Is that a Brazillian for your bonnet ?
Thanks guys
Bugger, forgot to pay for the e&b roll.
As penance will send some business your way, now that I know your shop exists :cheers:
JD, a couple of us fixed the EnB's for everyone. Although send some business Japspec way.
Helping each other is the way. Like we helped advertise the silver Dual cab :D
Advertised the number plate to send into a few unamed people in the right places.....
Good pics thanks heaps! Richard ill give you a buzz when i have ripped the pics off Gabs camera and bring them around on a USB. we got quite a few of your GTR cruising.
haha she was like wow wtf!
hahahha it's a man thing
Have you ever wondered why Richard got the GTR painted in that blue?
Should change your plates to Viagra.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
