2008 Evolution X MR Black PB on E85 (switchable 98RON map)
45000km reg. for 9months inc. custom plate
I've owned it for a bit over a year now, bought at 38K KMs and have since changed oils twice and also driveline fluids were changed last month. Fresh SST fluid was also changed about 6 months ago with new filter ($600+ Cost).
Was actually bought by a forum member here who owns an R35/Audi TTRS.
Has service records till I owned it. Due to the nature of the car I opted to get the car serviced at Willall and now at Driven Motorsport here in SA ( Jon was trained at Ralliart).
Car has been tuned by Beeble in Victoria - no actual dyno sheet as it was road tuned but initially it was putting out 221kw on the Willall dyno and we netted about 30% extra with the Beeble tune so go figure!
I have ALL stock parts. Everything listed below in the mod list i still have as well, including all replaced parts. Also 2x brand-new tyres sitting in the garage.
As you can see a lot has been done to this. Over $26000 in quality aftermarket parts let alone before labour and tuning costs!
I've never personally tracked it, basically drives me from home to jobs and uni with the occasional hill run.
Originally bought from Victoria - this was the official 'Ralliart' Car for Mitsubishi and their press events hence all the OEM extras
Price: $55000
Brakes:
- APP 2 piece front rotors
- APP Front brake pads - November 2013 changed to Girodisc
- Ferrodo Rear brake pads - November 2013 changed to Girodisc
- APP SS Brake lines
Exhaust Sytem:
- Tomei Ti Expreme Catback - November 2013 Invidia Q300 Catback
- Tomei Ti Expreme Straight Pipe
- HKS Dump Pipe (GT Extension Kit)
- HKS Front Pipe (GT Extension Kit)
- Touge Factory Titanium UICP
- ARC BOV Pipe
- Perrin Turbo Inlet Pipe
Oil/Fluids:
- ARC Engine Oil cooler
- AMSOil 5W30
- OEM Oil Filter
- Diaqueen SSTF (SST Valvebody Replacement in July)
Engine Bay:
- Password JDM CF Radiator Shroud
- Password JDM CF Engine Cover
- Password JDM CF Spark Plug Cover
- Password JDM CF Powerchamber Intake
- Password JDM Dressup Kit (Red)
Bracing:
- Carbing Front Strut Brace
- Carbing Rear Strut Brace
- Carbing Lower Arm Bar 2 Point
- Carbing Center Frame Brace
- Whiteline Front Sway Bar
- Whiteline Rear Sway Bar
Suspension/Wheels:
- BC Racing RM Coilovers
- Orange TPMS
- Varrstoen 3.3.2 19x10.5 +12
- Federal 595SS 265/30/19
- Rays Duralumin Blue Lock Nuts - November 2013 changed to Muteki SR48 Neochrome
- Front RHS Driveline replaced November 2013 (CV Joint failure)
Cosmetic:
- Varis CF Rear Diffuser
- OEM Aero Front Lip
- OEM Aero Side Skirts
- OEM Aero Rear Corner Air Dam
- OEM Aero Front Fog Light Delete
- OEM Aero CF Front Bumper (Ralliart)
- OEM Aero CF B Pillar Trim (Ralliart)
- OEM Aero CF Mirror Covers (Ralliart)
- OEM Aero CF Rear Wing Sticker Trim (Ralliart)
- OEM Aero Rear Spoiler Extension
- Polished Steel Relay and Fuse Covers
- LED Parkers and Interior Lights
- Cree 7W LED Reverse Lights (not installed)
- Sokei Hood Dampers - July 2013 changed to Prosport Carbon Fiber Hood Damper Kit
- Sickspeed Red Horn Upgrade
- Rexspeed steering wheel CF gauge holder
- Perrin 4" Antenna
- Beatrush Side Number Plate Bracket (not installed)
- Varis Style Side Skirt Extensions (Rexspeed) (not installed)
- CF Intercooler Panels (Rexspeed) (not installed)
- CF Parking Brake Handle (Rexspeed)
- APR CF Front Splitter (not installed)
Gauges:
- Defi Racer 52mm Boost Gauge (White)
- Defi VSD-Sports HUD Display
- AEM Digital Wideband UEGO 30-4100
- AEM Digital Oil Pressure 30-4407 (not installed)
Fuel System:
- Injector Dynamics ID1000 1000CC Injectors
- Works Engineering Stage 1 AFPR
- SARD Fuel Pressure Gauge
- Aeromotive 340 Fuel Pump
- BlaqOps Fuel Pump Fit Kit
- Jegs Inline Fuel Filter
Miscellaneous:
- Grimmspeed 3-Port EBC
- Forge Motorsport Actuator
- Cusco Oil Catch Can
- Upgraded Fuel Pump Relay (Green)
- Bosch Icon Wipers
- HKS D1 Oil Cap
- OptiCoat Paint Protection
- Nanotech Window Sealent
- Tactrix Openport 2.0
- Fire Extinguisher + Seat Bracket (not installed)
- Optima Yellowtop Battery
- Rear guards flared
Sound System:
- Focal FP 4.75 4CH Amp
- Morel Elate 6 two Way Splits
- Audison bit-Ten Processor
- Dynamatted Front Doors
Old pics. Will have updated ones soonish.
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
