here is a printout of my last suspension check from pedders...pretty sure he just set everything for general usage..which is all it gets with the occasional track day
I dont really have any adjustable stuff other than toe..I have some adjustablke fornt castor bushges but never installed them...it Just has a set of bilstein shocks/springs , it sits fairly low at the front especially..
does everything else look ok or does it look seriously out of whack??
I mean there is a degree of camber missing at the front left and a few opther thigns slightly out but I assume not enough to make a difference..i
any thing I should look into..??
https://www.sau.com.au/forums/topic/415996-opinions-on-settings/
Camber is 1 degree out, and its on the left front so you might notice the car pulling slightly to that side. You have a heap of caster (which is good).
Other then that there's no specified values for toe so who knows if its out or not, it will normally tell you the range for that specific car.
If its not scrubbing tyres or pulling I'd say leave the car as is, if you want it set up for track maybe get a proper alignment done at a recomended place, just be carefull where you go, you would be very surprised how many wheel alignment places dont know wtf they are doing.
Too much front camber for a road driven car. You'll get away with 1.5deg on the front and even out tire wear.
Front toe is okay
Rear camber is okay rear toe is neutral and probably toeing out dynamically when driving down the road.
Get the rear toed in 1mm each side and gain some straight line stability and predictability in the rear end
it was mostly just a check after a bingle to make sure it was all true but im pretty sure adjustments were made as well
the camber wear isnt a concern as It only does a few thousand kms a year.. happy to have it set for performance as long as its still comfortable to street
I think the front castor came from fitment of lower control arm bushes, I have adjustable castor rod bushes as well but not installed yet
rear toe is something I thought was usually set a degree or so inwards too so may get that done
It drives straight as an arrow so no concerns there either...Im just thinking just a set of sway bars and i will leave it as is...
:cheers:
However the caster split favour the LHS and caster has more effect on a left/right "pull" then camber thus Artz's car drives reasonably straight.
Chuck some bars on it old man ;)
i forgot your a suspension guru Hank..
it seems to handle pretty well, i throw it into corners often when I think im going to fast and it always holds on..R comps tyres do help somwhat I guess..it only squirrels around when they get hot
How much was it for the check? Do you just ask for a basic suspension setup check?
Would have just been a wheel alignment
Edited by Hank Scorpio
Was Initially a suspension safety check...i then replaced front ball joints, tie rodz and lca bushes and with driftworks bushes.. Followed by a full alignment...
Seems settings are ok and it drives try so I won't worry...
Some extra toe at rear and swaybars should make it a little more stable..then i need a diff :/
What size sways work best on the r33?
24mm adjustable on the front, plus a 22 or 24 adjustable on the rear. If you prefer a more oversteery behaviour (or more to the point, if you absolutely loathe understeer) then the bigger rear bar is the choice. If you set the front bar to max stiff and rear bar to min stiff, the balance is still OK. If you put a 22mm rear on, then you probably won't want to go to max stiff on the front.
BUT......all the above is somewhat dependent on what spring rates you have.
30km/h is not fast artz.
youve gone to the point of r compound tyres, why not some china crap adjustable arms?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
