Due to financial difficulties, its time for my baby to go =(
ITs a GTST TYPE M Series 2 skyline with ABS brakes.. so its the late 96 model, realeased early 1997...
Includes:
White
5 Speed Manual
ABS Brakes
SRS Airbags
Apexi 6" exhaust tip with 3" piping from turbo back
Apexi front Strut bar
Apexi S-AFC
Apexi Rev/Speed Metre
AVO front mount intercooler (Fitted by AVO)
Blitz blow off valve
Trust Airinx air filter
Tein adjustable suspension (front and back)
HKS Turbo Timer
HKS Electronic Boost Controller (In Cabin)
Sony CD/MD Player
Sony 6 stacker CD
Two 10" Cross Fire Subs
Two 200watt x 2 Cross fire Amps
Viper Alarm with Immobilizer
New Tyres jus put on too (worth $900)
(The Boot is professionally set up and looks awesome with the leather)
Tweaters on pillars (not sure what brand- came with car)
Aggressive Chin Spolier
109,800 kms
Ive only had the car for three months and am the second owner.. Trouble wit cops and fines and its really digging into my pocket.. Cant afford to keep as im at uni and not working much.. Has ALL receipts of modifications done in Australia, and has every single SERVICE receipt too.. Serivce and oil change done every 5000-9000kms.. I've only ever used optimax fuel too.. I have not had one problem with it.. very clean car and great for a first car buyer..
Not one scratch or dint expect for a slight crack on the chin spolier (Approx. $100 to fix).. Awesome to drive..
im looking for 24 k ONO, will be flexible for serious buyer.. Rego until next march.. New tyres put on ($900 worth). Serviced one month ago.. Looking for quick sale..
PM me for more details and pictures...
Cheers
Rob...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
