Sorry, for the seemingly rude title, but it is an eye-catcher eh? So, my conundrum is one that has been covered countless times it seems, but none of the guides or tips seem to fit me whatsoever, so I will need some resident expert's help in discovering exactly what it is I have. My mechanical knowledge is general across all platforms, every engine type, not rudimentary, but certainly not Skyline-specific, so forgive my seemingly novice outlook on this issue.
Now, the issue at hand stems from me cracking a head out on an excursion, and with no option in sight, limping the car back home. Obviously, this was less than helpful for the old RB20DET, so I decided to nix it in favor of the bigger, better RB25DET, which is now sitting nice and pretty mechanically in the bay of my car. The issue here lies in getting the brains of the car to work, ie the fabrication of the wiring harness for the R33 engine in the R32 Chassis. There are numerous guides on the swap, but none that delve deeply into the wiring side, and absolutely none that seem to match the physical wires I have in front of me. If I were to post pictures, could you identify for me what series harness I have, and what the best approach to making them work would be? I am in possession of both a stock RB20 and RB25 harness and ECU, so any combination is possible, i just need a resident expert to tell me what wire to chop and swap to get my daily driver back.
Much appreciated!
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
