starting from where I had left off the RHS body work restoration repair
all sanded down using this wonderful tool
BOSCH Orbital Sander ;)
This bit was the hardest and hard to reconstruct some of the body work with some selleys autofix - I will have to replace the RHS sill completely in the future :(
next bit.................I also removed some of the adhesive that sits between the sill so had to refill it using this ^
here is the Sikaflex applied - looks messy there but I tidied it up after it dried
here is another pic just for the hell of it.....................I also filled some of the factory gaps with Selleys autofix and sanded it down with some 1200 grit paper
so now it is all ready to be repainted
mandatory covering and drop sheets first
I thought I would experiment and use this - some Rust Guard expoxy enamel. Yeah its a topcoat but I don't really care
First coat done
2nd coat
after the paid dried I used some Dupli Color auto spray DSSB01 which is basically the Nissan Crystal white color
instantly whiter
and a final shot - I did apply a clear coat on afterwards but messed it up - so I've re-sanded everything and started again.
Will post pics up of final result soon.
  • Like 1
I also thought I would give the side skirt some TLC
dirty
cleaner
tar is a bitch to remove but all possible with some patience
mucho bettera ;)
I also got my trusty powerfile out of my toolbox................
and removed the old adhesive that was glued on and smoothed / flattened out some of the interior edges for better attachment
The rear bumper bar is really looking for the worse
Paint cracked
more cracks
and more
yeah..........needless to say it needs to be repainted
so I removed the rear bumper altogether
and started to paint strip it
this process is going to take some time.............. :dry:
Yesterday I proceeded to clean up the rear end of the car
excess exhaust residue and silt
better........
these rear number plate lights and clips are going to get a very nice clean too :yes:
will post more pics up soon
From memory, you need to remove the boot trim that runs along, from tail light from tail light, inside the boot. There are a few nuts that are near the "Skyline" logo
Got any tips at how to get the rear bumper off? Mine seems to just hang there by the top supports but I don't know where they are.
The bottom just flaps around.
Looking good Ants. Just a tip for future the best thing to remove tar off anything on your car is some prepsol/prepwash. Comes off in no time with no effort.
thanks mate. its not much for the moment but there will be some interesting pics soon enough.
Yeah, prep wash kicks ass and is what I used to remove the tar ;)
  • Like 1
They cleaned up real nice
thanks mate.
Lights are top notch anth; what was the process involved? LED's would be great as standard bulbs are "usually" rubbish.
cheers. The process is relatively straight forward
you first need
some dirty lights ;)
like these :rolleyes:
then........................
get your hands on an old tooth brush and some laundry powder and just scrub the lights with some hot water and rinse off (after you have taken the light cover off)
the results..............I applied a little bit of plastic cleaner as well just for more show ;)
there we are.
Next stop will be LED lights as yes the standards are crap. But then again these are number plates lights so being conspicuous could help out...................maybe :P
  • Like 1
Haha just a bit 'elbow grease' hey... that makes all the difference :yes: of course!
Officer... I don't know why the LED's are playing up on me I swear :whistling:
lol...................at least they will be clean ;)
What's going to be next after the LED's are done?
More restoration work perhaps :sweat: there can't be that much left...
well............yeah more restoration work.
I have some things in the pipe work which I wont mention just yet ;)
One thing is for sure is that after I have paint stripped the rear bumper I will get it painted professionally and should look a LOT better than before.
Keen to get this car running again as soon as possible.
i am very envious of your set up!!!!!
very very good work, seriously... i really respect that you just have a crack and are prepared to make some mistakes and do things yourself! great job and keep it up!
im up in QLD now so hopefully down the track (pun not intended) i see this machine at something SAU related (although im away ALOT this year for work).
Good work!
Dan
Good work!
Dan
thanks for the supporting words mate much appreciated.
I'm not afraid to get my hands dirty but sometimes wished I had more time to devote to this passion of mine.
I guess all good things take time though :)
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
