Do you flat and polish your panels after you've painted them Ants? It is a bit of extra work, but I find when using rattle cans it is essential to getting a really high quality finish. Not too necessary with white, but still makes it look a lot better.
In most cases I would, however because the panels that have painted are not really going to be visible I did not bother.
If it was going to be like a spoiler or bumper yes, although I rather give it to my local smash repairer for that pro finish :)
I would like to invest in an a good quality air compressor though and then maybe open a restoration business for Skylines ;)
  • Like 1
Ah I see, understandable. I've got a spray setup with a compressor and guns, but I only use it on larger panels or panels where I need to paint match. If I'm spraying a small object from my car black or anything that doesn't need to match my white, then I prefer spraying with a rattle can then flatting and polishing. The paint is cheaper and it takes less time than setting up the guns, mixing paint, then cleaning everything after :glare:
Nice idea, you definitely have the patience and eye for detail to do that sort of work!
thanks mate. Would need much money to setup something like and everything I have is invested in car, wife, kids and the BIG one.......mortgage
Should I win the lotto perhaps......maybe.......actually hell yeah.......I would have cash to burn lol
Just read your thread from start to now, fantastic work, I've owned my 32 for over 10 years and would love to be able to restore it with the same level of detail, congrats mate!
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
