Antz 1994 R32 Gtr Project & Restoration
I just read this thread start to finish..... I bought the 33 for this purpose... and the rust posts make me cringe
Truly epic and I love the build . Im keen as to wrinkle paint my covers ... hard job ?
thanks mate. Rust on theses cars are rather notorious but they are getting on as well (age wise). Best tip is get to it before it get to you.
Wrinkle paint is easy as long as you follow the instructions I have put a thread for VHT wrinkle painting on SAU here is the link
http://www.skylinesaustralia.com/forums/topic/426649-vht-wrinkle-plus-doing-it-right/
hurry up and tune already...
on a side note might be up your way in SEP so will make sure i drop by and say hello to you a nick and anyone else
Yeah, should tell Sean that.
You should. Just give us the heads up first though.
sif let you know....was just going to rock up with bishes! start the party! lol
that would only work if the bishes you bring are hawt - if not...............GTFO
Hey Antz,
So, I finally got around to looking at your build thread. Quite a read. Did you want me to pause the flow of emails to EFI so that they can spend more time working on your car :P
Thanks benno. I think it would be wise not to do that considering its almost there. But thanks for the offer mate ;)
Great to see it alive!!
I almost thought it was a bit of shuffle at the start but I think it's just the noise of the BOVs on low-medium load?
Yes, it is good to finally see it running on all 4s :D
I think it is just the BOV which is fluttering like it should do.
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
