Good work man, awesome to see !
Did you find perfect run to be cheaper than RHD ?
The answer to that is yes, yes and yes. They are excellent to deal with and fast delivery.
Edited by Ants
Been frantically trying to put the car back together
So first up the I took the front LHS mudguard off completely and gave it a good wash (really stupid I know but I'm anal :w00t: )
I also got to tidy up the vents in the mudguard for the oil cooler as they used to look like this
Pretty bodgy job done IMO :closedeyes:
Smoothed them out like so with the powerfile....mucho bettera
Then time to tackle the LHS front fender
Glue and sikaflex and other crap on it
Most of it removed and cleaned up with Motospray Prep Wash (which I highly recommend)
the bolts, washers and nuts were pretty fubared
so replaced with some brand new ones sourced from supercheap auto
Photo of front fender put back on car (still not fully bolted back into place but were getting there)
I managed to put the brand new LHS N1 headlight into place
and also managed to put the other N1 headlight on the car, which already has changed the appearance of the car.
Edited by Ants
Ok I am going throw a spanner in the works here and ask for you guys to help me :w00t:
For the project I wanted to put something on that makes the car perform well and looks the goods too (besides the engine itself), so I have been tossing up between
this
Nismo intake plenum - costs $1,982 (inc. p&H, duty + GST)
or this
ACPT carbon tailshaft costs approx. $1,700 after P&H, customs duty and GST (and yes I did the calculations) from Vivid Racing
Please ignore the differences in costs between each items as that is not what I want to focus on (although every $ hepls) and I can only afford to have one of the above. I have heard some positive and negative things about both items but cannot reach a decision so I am going to let you guys do it for me :D
Whatever conclusion is reached, I will buy it and it will go on the car.
BTW my car will be mostly street orientated to start of with but then focused on track work.
Happy decision making!
Neither carbon shaft causes vibrations and nismo plenum does nothing
Happy to consider that option as well mate. But there must some benefits somewhere???
Edited by Ants
There definitely has to be a better way to spend the $1,700 with more tangible results - what are you doing suspension wise? Changing any of the stock arms for adjustability?
I am begining to think that you are right, which is why I probably couldn't come to a conclusion.
Will be replacing the old (worn out) el sport suspension (has HKS) coilovers) with either Tein or BC racing suspension(not entirely sure which one yet). Have not thought about any other suspension mods as of yet. But would like to put down as much of the grunt to the bitchumen so need to think about that too.
Edited by Ants
Having had a carbon shaft, you can DEFINATELY feel the "on/off/on" throttle response impove. However, mine was a bucket and the amount of vibration that was going through the car was rediculous. IF the company could totally 3000000% garuntee that it wouldn't be unbalanced, i'd buy another one and try again.
Torqline in the UK seem to get a good wrap. I know God_Speed has one on his NUR and there isn't an issue.
Really sad to hear your carbon tailshaft was a dud. In fact it is quiet disapointing because you do pay good money for something like that.
Yep, improvement in throttle / engine response is what initially caught my attention to potentially buy a carbon tailshaft. But there seems to be some gremlins surrounding this.
Maybe should bite the bullet and just go with carbon tailshaft and if it sucks well I will put the old one back on.
Edited by Ants
http://www.skylinesa...bon-driveshafts
PST ones seem to get a pretty good rap, looks like a heat issue in the 300zx link posted in that thread with the exhaust sitting right under the driveshaft - $$$ could be pretty good from the USA
Edit: although - shipping from the USA is usually a farce
That Torqline CS composite tailshaft is a nice bit of gear; It is such a shame it hides under the car :D
I have just requested a quote from torqline. Got a feeling it is going to be more costly than the ACPT item...but I will let you guys know :teehee:
Edited by Ants
Worth it if it actually works and you don't have to "make it work". haha
If you do go down the path of suspension arms, etc check out the SPL gear out of the states. Top shelf stuff & all their z32 gear will work for you.
Also, love your build!
Thanks mate,
I Will check it out.
Edited by Ants
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
