Farks sake Ants. You may have just convinced me to pull my turbos off as well... 450kw is so tempting....
aint just the turbos Anf but more importantly having the appropriate fuel system in place to support the requirements for that level of power
I have everything needed all I need is the haltech and turbos if I want them. Meh. Other stuff first. Really happy for you ants it's a great result!
thanks and doooooooo eeeeeeetttt!
What did it make on 98? How far did you push it there?
Any plans to take it down the 1/4?
I think on 98 it made just under 400rwkw - but was advised that as soon I start mixing (with 98) a chunk of boost is pulled right out for safety
Considering the increase in distribution and having E85 so close to me, I highly doubt I would want to switch back to start putting 98 back in
QLD SAU drag day next weekend Piggaz
Gonna be interesting
Hey Ants, apart from the exhaust manifold porting (and maybe some sort of Tomei head studs that came with the engine), have you done anything to the head or is it still OEM?
Congrats on the result mate!
apart from the tomei cams and combustion chamber correction the head is indeed still standard i.e. no porting, still standard valves, guides and springs
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
