Was it the earth strap in the engine bay ?
I think the attessa system has more earths under the back of the car in the boot?
Glad it's sorted mate go hard !!
yeah. The earth that holds the car battery as well as an other earthing wire.
It goes alright lol
  • 2 months later...
Rightyo its been a while since I did anything with this thread
Heres a few pics of the car at Lakeside Raceway back in October
lol @ that wrxy handycam
#DATE85LYF
Cars cooling off after the session
c91024f0-d6f5-4095-b1c0-d2363a83740f_zps
the brakes were fecking hot - need to fabricate some brake cooling / air ducting next also that brake dust is nasty, predominantly because I think my rotors are not facing correctly :dry:
cleaned her up once I got home
enjoyed a well deserved beer :cheers:
  • Like 3
Been experiencing voltage drop at idle after driving the car and think it could be the battery
Over the years I have been going through wayyyyyyyyyyyyyyy tooooo many batteries
And after some research I am thinking my alternator is one its way out.
So I procured this
RH9 Alternator 130amps - hope this fixes the voltage drop issue (fyi it drops from 13.5 to 12.8 or lower at idle)
Came with this sticker - so cool - not that am worthy of putting that sticker on lol
  • Like 2
Nice shots antsy pants
thanks dude
Nice work. Was that a general fun day @Lakeside?
btw looks like one of those rear pods is sticking out a bit?
Yep, was SAU QLD happy laps at Lakeside has to be my favorite track
Yeah, I have since fixed that rear pod but may have to sikaflex it
So I procured this
and not only do they work really well they look blingy too :thumbsup:
Edited by Sinista32
Next issue.
Miss firing whoes.
I had my plugs fouled at the drag day so I thought I would replace them.
I took the coil packs out and they looked like this
f35c70b0-9c7b-4098-bd59-b57bde4d670a_zps
they needed some serious TLC
While I was at it thought it would be good to source a new coil pack harness as the other one looked rather brittle and stiff
also got some brand new NGK platinum spark plugs BCPR7ES and I gapped them to 0.7mm
baf8d6e2-79ef-444c-a3b4-11b28ebcd86d_zps
I cleaned up them coil packs and also go hold of some dielectric compound and applied it to the coil packs where required and also around the spark plugs
Plugs, coil packs and new coil pack harness all reinstalled
Went for a drive and car felt more responsive but more importantly goodbye missfire, happy Frenchmen I was
  • Like 3
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
