Shell is no go as she's in bad shape underneath
Thinking my car ain't that bad and may fix it.
Will see. Will just save more cash and buy a late model outright lol
strip shell.
take shell to bare metal.
reapir metal.
do some fancy shit. rebuild.
it needs to be done properly ants.
as you pull apart you write down whats broken....
strip shell.
reapir metal.
this ^ is whats on my mind and I can do it all in my garage
gonna be messy lol
but will look good once done
  • Like 1
lets face it these cars are showing there age and if you want to keep your R32 in good nick then your kinda better off stripping it all apart and then getting the right bits and pieces replaced especially the body.
its just the way things are with mother nature doing its thing and taking back its precious elements.
I still would like to see other BNR32 shells out there just to compare as so far I can tell you that its seems difficult to find one that is in a good state.
Acid drip to strip all the paint, replace any damaged panels with brand new. Stitch weld, 12 point cage. Electra dry carbon hanging panels painted body colour Because racestreetcar
almost. you may get away from stripping all the paint and only stripping whats necessary. only one way to find out.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
