R33 Series Ii 4 Door - Quality Build & Tune (Drift Project). Priced To Sell Fast...
White 1996 Serries II ECR33. 4 Door GTS-t.
Spec Lists:
Engine:
-RB25DET
-Blitz SUS air filter and Blitz inlet pipe
-Greddy 3" downpipe
-Rising Sun Performance Stainless decat pipe (+orig cat converter for rego)
-5Zigen Fireball exhaust system (cat back)
-Greddy TD05 turbo kit
-Blitz LS front mount intercooler
-Blitz Blow off valve
-19 Row Oil cooler with speedflow fittings and Greddy thermostatic 4 way sandwich plate (-10JIC fittings all round)
-Greddy Oil catch can
-HKS 740cc injectors
-Nismo Fuel Pressure Regulator
-Z32 AFM
-Apexi Power FC with hand controller
-Blitz Dual SBC Spec-R Boost Controller
Drivetrain:
-KAAZ 2-Way diff (new)
-Exedy Heavy Duty Sport Clutch
-Full GTR Brembo brake conversion with HEL stainless steel brake lines
-GTR EBC grooved front disks with red stuff pads
-HICAS lock out
Suspension/Chassis:
-Kazama Castor Rods (to be fitted)
-Cusco type OS Front Strut Brace
-Nismo Rear Strut Brace
-HSD/Dritworks 'CS2' fully adjustable coilovers
Interior:
-Razo Pedals
-Razo Shift Knob
-Alpine H/U with 6" speakers all round with tweeters (and cables for sub in boot)
-Full Defi BF 60mm compliment (Boost, Oil pressure, Oil Temp) with Defi visors
-Defi Link Meter Taco 115mm with shift light
-350mm Sparco suede steering wheel with Q/R hub and Nismo Boss kit
-Turbo timer
-PLX Devices AFR unit and 52mm gauge in Defi cup and stand
-Cobra alarm & immob.
-Nismo Key and spare
-Battery relocation parts installed (for battery in the boot)
Exterior:
-17 inch Super Advan tri-spoke two piece alloys (white with polished lip)
-255's on rear and 235's on front
-Nismo from bumper with '2 door' fog light conversion
-D-Max Carbon Fiber GT wing
-Side skirts & rear pods (to be fitted)
-Tinted rear glass and doors
- Side skirts and rear pods - very rare (to be painted & fitted)
The engine and gearbox are excellent. Dyno sheets available on request.....243kw at 1.1bar.
The susspension is new. The diff is new. The gauges are new. The turbo is practically new. The body work and paint are excellent. Straight car with no rust.
Currently in "storage" but I will sell with full 12 months rego.
$14,000
Call/text on 0420 577 599 if you are interested.
I'm pnly in ustralia till 18 Jan so please text/call before this...
Cheers wooa (Anthony)
Edited by wooa
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
