For Sell; Apple Iphone 5 64Gb & Bose Lifestyle V35 Home Theater System
We give 90 days return company policy. We will give you your choice of a full refund or a replacement item if available. Please bid with confidence.
Brand new Bose Lifestyle V35 Home theater system cost ( 1000usd )
What’s In The Box:
* Control Console
* Acoustimass Module
* ADAPTiQ Audio Calibration Headset
* Universal Remote Control
* iPod/iPhone Compatible Dock
* 4 Jewel Cube Speakers
* Horizontal Center Channel Speaker
* Front Speaker Cables
* Rear Speaker Cables
* Acoustimass Module Power Cord
* HDMI® Cable
* Power Supply
We make shipment via UPS, FEDEX and DHL shipping company 2days deliver world wide.
The shipping fees cost $50usd
If you are serious buyer get back as soon as possible.
Thanks.
[email protected]
BBM CHAT 24HRS: 275DD6E1
call Hotlink 24hours : +97470540287
SMS : +97470540287
  • 11 months later...
strong first post kent.
this fit in my skyline?
I think it'll fit right in the engine bay! Although you might have to cut the bonnet out a tad to let the system hang out like a bug catcher ;)
    • Get a timing light on it and verify it's sparking reliably at a sane ignition timing. Use a COP extension lead to be 100% sure about timing instead of hoping that the timing loop on the back of the engine is accurate. Make sure it's actually injecting fuel. MAF is not used on the stock ECUs for initial cranking.
    • RE5R01A is the transmission. Didn't realize they had a 5 speed for the NA cars but for some reason the turbo engines stuck to 4 speeds. Looks like the solenoid block is still available from Nissan directly at a somewhat reasonable price: 31940-60X01 https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er33/6568-rb25de/trans/317 I would move sooner on this than later. The moment the de minimis exception for Japan goes away expect to be paying 25% tariffs even for stuff like this.
    • Only RB26 are low from factory. And even then the ECU actually want high impedance, because it's essentially the same ECU as the RB20 anyway, and thus they have a f**king resistor pack!
    • Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1
