Hi Guys,
i have been searching around for info on which way to go when it comes to upgrading the ECU on a R33 GTS-t manual.
can anyone shed their knowlege when it comes to upgrades as i am sure there are plenty of people asking the same question.
it seems to be the big question between
-NISTUNE
-Apexi Power FC
-Haltech Platinum Pro
-Vipec v44
i know price is a major factor, but is there substacial benifits of each ECU?
thanks in advance
https://www.sau.com.au/forums/topic/416039-r33-gts-t-ecu-upgrade/
Exactly the same boat that I've been in. Going to ring my tuner and see what their most comfortable with as we all know an ECU is as only good as the tune/tuner. But I'm leaning towards vipec, allows duel fuel maps (E85/98) and also MAF/map tunes.
Do exactly this
Ask your tuner and see what he recommends because an ecu is only as good as the tuner
The other factor is how much you want to remain undercover. Nistune keeps standard ECU and EFM. Looks and works like it's supposed to and could save your bacon when the bacon are perusing through your car. Aftermarket plugins that hide inside a factory ECU case are the next best, but take a lot of extra effort (and a faked up AFM) to camouflage to an equivalent level.
My comment on "ask your tuner" is that a good tuner should be able to handle pretty much any ECU that uses laptop software or a hand controller. It only takes my tuner an extra couple of hours to tune a car for the first time when it's something that he's never seen before (and that happens rarely enough these days) and he wouldn't think of charging the customer for that time. It's his self education investment.
Same guy is so sick of bullshit Haltech failures that he will still tune them, but will not help anyone to install one.
My tuner is so used to tuning power fc's that a complete new tune with different injectors,afm,turbo etc etc.. he got the car running reasonable within 5minutes, and on the dyno took no more than an hour then some small adjustments for half an hour..
in comparison the first tuner i used had it on the dyno for upto 4hours, another tuner asked me for the instruction manual WTF?? so i never used them, lol
Also LINK.
I'd go Nistune on a 8-bit Z32 ECU. I've got one myself. If your tuner doesn't know Nistune I'd be suspicious. However the Z32 into R33 requires more than basic knowledge to work correctly (remove knock sensor, fuel temp resistor, etc).
This has been done to death. In the end you're going to get LOADS of mixed responses because everyone is going to recommend what they have experience with (flying the Link flag myself) and you're not going to be any closer to an answer.
Best way is to just call up your tuner, see if he has a problem tuning any of the ones you are thinking of getting (mine couldn't care less), then do your reading on each one and see which one appeals to you the most. I ended up going with the Link because it ticked all the boxes I wanted and I could get it cheaper than a Vipec even though they are essentially the same thing (some will claim they are exactly the same thing, just different labels).
Also LINK.
Yeah I thought of nistune it'd certainly be the most economical on purchase price. But from my understanding (haven't done a tonne of reading yet so don't flame me) you are fairly limited on a Nistune compared to stand alone ECU's?
Limited yes. Limited to what the factory ECU can do - which is run the engine fairly bloody well. But if you want a bunch of aux outputs or tricky rev limits or boost control or dual maps etc etc, then you will need something else.
For a normal street car with a few mods (even up to quite serious mods) it will still be a good choice. Just depends on what your plans are.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
