Cleaning out my impulse buys and left over bits from the years gone by.
All parts are located in Brisbane, South Side, and inspections are welcomed, just message me on here or on Facebook and I will try and get back to you as soon as I can.
I will post at buyer's expense, so if you are located elsewhere and if you are interested, please contact me for a quote on freight.
Thanks,
Cameron.
Nissan BCNR33 Skyline GTR N1 Turbos
Near new condition
High temperature competition coating on exhaust housings
Selling due to going with a larger setup
$1250
post-19425-0-77200700-1356141201_thumb.jpgpost-19425-0-92537600-1356141213_thumb.jpgpost-19425-0-48906400-1356141221_thumb.jpgpost-19425-0-69639500-1356141229_thumb.jpgpost-19425-0-09798900-1356141241_thumb.jpg
Nissan BNR32 Skyline GTR G Sensor
Used G sensor
Worked perfectly before being removed from the vehicle
Hard to find these days without impact indicator showing
$250
BCNR33 GTR Skyline N1 Center Triple Gauge Cluster
R33 GTR N1 center triple gauge cluster
$100
Nissan Skyline GTR R32 R33 R34 RB26DETT Sard Twin Spray 800cc Top Feed Injectors
Supplied with plugs
Only removed from engine due to changing fuel to E85 and needing larger injectors
$500
post-19425-0-91218100-1356141298_thumb.jpgpost-19425-0-63560500-1356141338_thumb.jpgpost-19425-0-79428100-1356141343_thumb.jpgpost-19425-0-25937000-1356141349_thumb.jpg
Nissan Skyline GTR RB26DETT Carbon Fiber Timing Belt Cover
Unknown Brand
I bought it when I was in Japan
$100
post-19425-0-73587700-1356141388_thumb.jpgpost-19425-0-50075300-1356141401_thumb.jpgpost-19425-0-58678500-1356141413_thumb.jpgpost-19425-0-27088600-1356141430_thumb.jpgpost-19425-0-99918600-1356141437_thumb.jpgpost-19425-0-93739000-1356141482_thumb.jpg
Nissan Skyline BCNR33 GTR RB26DETT Boost Control Solenoid
Used Nissan RB26DETT Boost Control Solenoid
$50
Nismo Skyline BCNR33 Series 3 Front under Diffuser
Genuine NISMO S-Tune aero body kit front under bumper spoiler for the Skyline BCNR33 R33 GTR
Was over $1000 brand new :( (http://www.rhdjapan....ne-bcnr33-56310)
$550
post-19425-0-88764300-1356141528_thumb.jpgpost-19425-0-39001600-1356141513_thumb.jpgpost-19425-0-84121800-1356141542_thumb.jpgpost-19425-0-83038100-1356141535_thumb.jpg
Nissan Skyline BCNR33 GTR N1 RB26DETT Air Box and Snorkel
Nissan Skyline BCNR33 GTR N1 Air Box and Snorkel
K&N Air Filter
$250
Nissan Skyline BCNR33 GTR RB26DETT Air Flow Meters
Factory RB26DETT air flow meters
$200 for the pair
Trust/Greddy T78 33D Turbo Kit
Trust/Greddy Exhaust Manifold
Trust/Greddy External Waste gate with screamer pipe
Trust/Greddy Front Suction Pipe
Trust/Greddy Heat Shield
Custom Dump/Front Pipe
Trust/Greddy 3.7” “Hi-Power” Ceramic Coated Stainless Steel Exhaust
Hardly used, selling due to going back to a twin turbo setup
$3500
post-19425-0-11019900-1356141809_thumb.jpgpost-19425-0-62224600-1356141816_thumb.jpgpost-19425-0-23608300-1356141831_thumb.jpgpost-19425-0-54593100-1356141837_thumb.jpgpost-19425-0-65549800-1356141845_thumb.jpgpost-19425-0-70328400-1356141874_thumb.jpgpost-19425-0-94342800-1356141881_thumb.jpgpost-19425-0-02121000-1356145502_thumb.jpg
KSP Racing Equipment Carbon Kevlar Rear Bumper Cover to suit Nissan Skyline R33 GTST or GTR
Brand New still in box
KSP Brand
Carbon Kevlar
$200
Nissan Skyline BCNR33 GTR N1 Radiator
Used
$100
Rasty Mate FRP Boot for Skyline R33 GTR/GTS-T
Flat Truck Style
Painted in QM1 White
GT Wing Mounts
Some Cracks in the paint behind the wing mounts
Very light @ 5.2kg
$500
post-19425-0-31778100-1356143381_thumb.jpgpost-19425-0-97833600-1356143388_thumb.jpgpost-19425-0-38891800-1356143392_thumb.jpgpost-19425-0-86720400-1356143395_thumb.jpgpost-19425-0-96269400-1356143406_thumb.jpgpost-19425-0-03353300-1356143415_thumb.jpgpost-19425-0-91919200-1356143417_thumb.jpgpost-19425-0-97448500-1356143420_thumb.jpgpost-19425-0-53057000-1356143425_thumb.jpgpost-19425-0-30299200-1356143483_thumb.jpg
Full Carbon Fiber 1550mm 3D GT Wing
Cannot remember the manufacturer
1550mm Wide
Full Carbon Fiber Construction
$500
post-19425-0-92500700-1356143496_thumb.jpgpost-19425-0-79782300-1356143512_thumb.jpgpost-19425-0-10079500-1356143519_thumb.jpgpost-19425-0-72168300-1356143527_thumb.jpgpost-19425-0-28072200-1356143544_thumb.jpgpost-19425-0-50904300-1356143550_thumb.jpgpost-19425-0-46415300-1356143561_thumb.jpgpost-19425-0-98595000-1356143571_thumb.jpg
R33 GTR Front Lower Arms
Stock R33 GTR Front lower arms with both ball joints
I was going to modify to get more front negative camber, but I no longer need them
$150 for the pair
post-19425-0-82578400-1356143358_thumb.jpgpost-19425-0-30559500-1356143373_thumb.jpgpost-19425-0-49047300-1356143351_thumb.jpg
Nismo RB26DETT Engine Mounts
Brand New Still in Box
Nismo ones are a bit stiffer than Standard Engine Mounts
$150
Nismo Clear Indicators
$80
post-19425-0-48247000-1356142135_thumb.jpgpost-19425-0-12199300-1356142144_thumb.jpgpost-19425-0-14212000-1356142159_thumb.jpgpost-19425-0-52740100-1356142167_thumb.jpg
Nismo Carbon Fibre Side Pillar Garnish
$150
post-19425-0-35241800-1356144753_thumb.jpgpost-19425-0-25612400-1356144761_thumb.jpgpost-19425-0-65398700-1356144766_thumb.jpg
R33 GTR R200 Competition Diff
Brand New Cusco 2 way Center
Brand New Crown Well and Pinion
Greddy Extended High Capacity Diff Cover
Diff Cover has been modified to clear a close fitting exhaust
4.11 Ratio (Stock)
$2500
post-19425-0-87092200-1356143292_thumb.jpgpost-19425-0-18371900-1356143300_thumb.jpgpost-19425-0-42736800-1356143309_thumb.jpgpost-19425-0-68873300-1356143319_thumb.jpgpost-19425-0-81999300-1356143327_thumb.jpg
R33 Auto-R FRP Head Light Covers
Brand New
Very light and well made
$250
post-19425-0-40905500-1356143332_thumb.jpgpost-19425-0-37557000-1356143338_thumb.jpgpost-19425-0-91135500-1356143343_thumb.jpg
Injectors have been SOLD!
That T78 set up on my motor made 469awhp @ 18psi and it had full boost @ 5250rpm on the dyno printout.
Hi mate, how much power did you make at what boost with the t78 kit. Also what rpm did it come on full boost. Cheers
  • 4 months later...
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
