Cleaning out my impulse buys and left over bits from the years gone by.
All parts are located in Brisbane, South Side, and inspections are welcomed, just message me on here or on Facebook and I will try and get back to you as soon as I can.
I will post at buyer's expense, so if you are located elsewhere and if you are interested, please contact me for a quote on freight.
Thanks,
Cameron.
Nissan BCNR33 Skyline GTR N1 Turbos
Near new condition
High temperature competition coating on exhaust housings
Selling due to going with a larger setup
$1250
post-19425-0-77200700-1356141201_thumb.jpgpost-19425-0-92537600-1356141213_thumb.jpgpost-19425-0-48906400-1356141221_thumb.jpgpost-19425-0-69639500-1356141229_thumb.jpgpost-19425-0-09798900-1356141241_thumb.jpg
Nissan BNR32 Skyline GTR G Sensor
Used G sensor
Worked perfectly before being removed from the vehicle
Hard to find these days without impact indicator showing
$250
BCNR33 GTR Skyline N1 Center Triple Gauge Cluster
R33 GTR N1 center triple gauge cluster
$100
Nissan Skyline GTR R32 R33 R34 RB26DETT Sard Twin Spray 800cc Top Feed Injectors
Supplied with plugs
Only removed from engine due to changing fuel to E85 and needing larger injectors
$500
post-19425-0-91218100-1356141298_thumb.jpgpost-19425-0-63560500-1356141338_thumb.jpgpost-19425-0-79428100-1356141343_thumb.jpgpost-19425-0-25937000-1356141349_thumb.jpg
Nissan Skyline GTR RB26DETT Carbon Fiber Timing Belt Cover
Unknown Brand
I bought it when I was in Japan
$100
post-19425-0-73587700-1356141388_thumb.jpgpost-19425-0-50075300-1356141401_thumb.jpgpost-19425-0-58678500-1356141413_thumb.jpgpost-19425-0-27088600-1356141430_thumb.jpgpost-19425-0-99918600-1356141437_thumb.jpgpost-19425-0-93739000-1356141482_thumb.jpg
Nissan Skyline BCNR33 GTR RB26DETT Boost Control Solenoid
Used Nissan RB26DETT Boost Control Solenoid
$50
Nismo Skyline BCNR33 Series 3 Front under Diffuser
Genuine NISMO S-Tune aero body kit front under bumper spoiler for the Skyline BCNR33 R33 GTR
Was over $1000 brand new :( (http://www.rhdjapan....ne-bcnr33-56310)
$550
post-19425-0-88764300-1356141528_thumb.jpgpost-19425-0-39001600-1356141513_thumb.jpgpost-19425-0-84121800-1356141542_thumb.jpgpost-19425-0-83038100-1356141535_thumb.jpg
Nissan Skyline BCNR33 GTR N1 RB26DETT Air Box and Snorkel
Nissan Skyline BCNR33 GTR N1 Air Box and Snorkel
K&N Air Filter
$250
Nissan Skyline BCNR33 GTR RB26DETT Air Flow Meters
Factory RB26DETT air flow meters
$200 for the pair
Trust/Greddy T78 33D Turbo Kit
Trust/Greddy Exhaust Manifold
Trust/Greddy External Waste gate with screamer pipe
Trust/Greddy Front Suction Pipe
Trust/Greddy Heat Shield
Custom Dump/Front Pipe
Trust/Greddy 3.7” “Hi-Power” Ceramic Coated Stainless Steel Exhaust
Hardly used, selling due to going back to a twin turbo setup
$3500
post-19425-0-11019900-1356141809_thumb.jpgpost-19425-0-62224600-1356141816_thumb.jpgpost-19425-0-23608300-1356141831_thumb.jpgpost-19425-0-54593100-1356141837_thumb.jpgpost-19425-0-65549800-1356141845_thumb.jpgpost-19425-0-70328400-1356141874_thumb.jpgpost-19425-0-94342800-1356141881_thumb.jpgpost-19425-0-02121000-1356145502_thumb.jpg
KSP Racing Equipment Carbon Kevlar Rear Bumper Cover to suit Nissan Skyline R33 GTST or GTR
Brand New still in box
KSP Brand
Carbon Kevlar
$200
Nissan Skyline BCNR33 GTR N1 Radiator
Used
$100
Rasty Mate FRP Boot for Skyline R33 GTR/GTS-T
Flat Truck Style
Painted in QM1 White
GT Wing Mounts
Some Cracks in the paint behind the wing mounts
Very light @ 5.2kg
$500
post-19425-0-31778100-1356143381_thumb.jpgpost-19425-0-97833600-1356143388_thumb.jpgpost-19425-0-38891800-1356143392_thumb.jpgpost-19425-0-86720400-1356143395_thumb.jpgpost-19425-0-96269400-1356143406_thumb.jpgpost-19425-0-03353300-1356143415_thumb.jpgpost-19425-0-91919200-1356143417_thumb.jpgpost-19425-0-97448500-1356143420_thumb.jpgpost-19425-0-53057000-1356143425_thumb.jpgpost-19425-0-30299200-1356143483_thumb.jpg
Full Carbon Fiber 1550mm 3D GT Wing
Cannot remember the manufacturer
1550mm Wide
Full Carbon Fiber Construction
$500
post-19425-0-92500700-1356143496_thumb.jpgpost-19425-0-79782300-1356143512_thumb.jpgpost-19425-0-10079500-1356143519_thumb.jpgpost-19425-0-72168300-1356143527_thumb.jpgpost-19425-0-28072200-1356143544_thumb.jpgpost-19425-0-50904300-1356143550_thumb.jpgpost-19425-0-46415300-1356143561_thumb.jpgpost-19425-0-98595000-1356143571_thumb.jpg
R33 GTR Front Lower Arms
Stock R33 GTR Front lower arms with both ball joints
I was going to modify to get more front negative camber, but I no longer need them
$150 for the pair
post-19425-0-82578400-1356143358_thumb.jpgpost-19425-0-30559500-1356143373_thumb.jpgpost-19425-0-49047300-1356143351_thumb.jpg
Nismo RB26DETT Engine Mounts
Brand New Still in Box
Nismo ones are a bit stiffer than Standard Engine Mounts
$150
Nismo Clear Indicators
$80
post-19425-0-48247000-1356142135_thumb.jpgpost-19425-0-12199300-1356142144_thumb.jpgpost-19425-0-14212000-1356142159_thumb.jpgpost-19425-0-52740100-1356142167_thumb.jpg
Nismo Carbon Fibre Side Pillar Garnish
$150
post-19425-0-35241800-1356144753_thumb.jpgpost-19425-0-25612400-1356144761_thumb.jpgpost-19425-0-65398700-1356144766_thumb.jpg
R33 GTR R200 Competition Diff
Brand New Cusco 2 way Center
Brand New Crown Well and Pinion
Greddy Extended High Capacity Diff Cover
Diff Cover has been modified to clear a close fitting exhaust
4.11 Ratio (Stock)
$2500
post-19425-0-87092200-1356143292_thumb.jpgpost-19425-0-18371900-1356143300_thumb.jpgpost-19425-0-42736800-1356143309_thumb.jpgpost-19425-0-68873300-1356143319_thumb.jpgpost-19425-0-81999300-1356143327_thumb.jpg
R33 Auto-R FRP Head Light Covers
Brand New
Very light and well made
$250
post-19425-0-40905500-1356143332_thumb.jpgpost-19425-0-37557000-1356143338_thumb.jpgpost-19425-0-91135500-1356143343_thumb.jpg
Injectors have been SOLD!
That T78 set up on my motor made 469awhp @ 18psi and it had full boost @ 5250rpm on the dyno printout.
Hi mate, how much power did you make at what boost with the t78 kit. Also what rpm did it come on full boost. Cheers
  • 4 months later...
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
